Wiring harness question
Old Jul 7, 2015 | 04:58 PM
Billgluckman's Avatar
I wasn't sure where the best place to put this was..
I've got an 88 sc, originally a v6 car, but has has a carb'd sbc for years. The car caught fire a while back and ruined the harness from the firewall forward. I'm currently tearing the car down for rust repair, paint, and to get it running again. I need to know what all year engine harness (from firewall forward) will plug into my chassis harness.
I had a harness from a tpi car, but it would no plug in at the firewall, so I'm sure I'll have to use the 2.8 harness. Are there any differences in the years?
I'm also considering going aftermarket with the whole harness, but painless is expensive. I found E-Z Wiring makes a cheaper harness, but it doesn't come with the engine harness from what I could tell.
Old Jul 7, 2015 | 08:37 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Wiring harness question
If ur car is an 88 u can prob get a tbi or mpfi harness and use that as a donor if ur keeping the carb set up u mostly need alt, temp sender wire, grounds, dist harness for either external coil or in cap, oil pressure harness down by the oil filter wont need o2 if ur using ac u just plug that into the tbi or mpfi harness all the grounds that gon to the back of the head knock sensor if ur using external coil and distributor i know there is prob a few im missing but thats most ull need
Old Jul 8, 2015 | 09:36 AM
Anyone know any aftermarket harness that aren't crazy expensive?
I wouldnt mind replacing the whole thing. Bumper to bumper.
Old Jul 9, 2015 | 11:52 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Look up the member "Pocket" here on the site. he can build a new harness from scratch. Not sure on his prices though.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
