extremely sluggish 305
Old Jul 24, 2015 | 12:07 PM
Al Nonymous's Avatar
Car: 1992 RS
Hello, My 92 305 TBI with a 5 speed is so sluggish it's just nuts. It's been gradually getting worse. It has pretty new AC Delco plugs and 8mm wires. The cap and rotor I haven't replaced. It idles fine and never stalls but I have to be light on the pedal or it just kind of boggs down. I'm going to go get a cap and rotor now just because I haven't yet. And I haven't done anything else to it either except changed the oil and filter and I did change the fuel filter and air filter. What do you think I should do to just make it feel like it's basically supposed to? I would really appreciate any advice. Thank you.
Old Jul 24, 2015 | 12:35 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: extremely sluggish 305
Could be a clogged cat.
Old Jul 24, 2015 | 02:15 PM
Car: 1992 RS
I put in a new one a lil over a year ago to smog it. Could it be that if it's that new? Sorry I didn't mention that before.
Old Jul 24, 2015 | 02:55 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Could be a number of things. Low compression being the worst. Bad gas, low fuel pressure clogged fuel filter coil going out, 1 of the 2 injectors not spraying correctly egr stuck open. Fuel pressure regulator going bad. Start with a compression test see if its good then spec all your egr components then fuel then ignition system
Old Jul 25, 2015 | 11:52 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Sounds like a fuel delivery issue, definitely replace the fuel filter and run good gas through it and see if you notice a change, then I would start looking at fuel pressure and injectors. If all those check out I'd move onto spark. It's a good idea to go get a new cap and rotor since it's a quick and easy change
Old Jul 25, 2015 | 01:18 PM
Car: 1992 RS
Thank you guys. I will look into and try what you've said and post what I find out. I appreciate the advice.
Old Jul 25, 2015 | 09:54 PM
ex-x-fire's Avatar
Make sure the ign. timing advances when you rev it. If it doesn't, it'll feel like a 2.5.
Old Aug 31, 2015 | 06:15 AM
Saxondale's Avatar
Car: 84 Z
Never hurts to put in a new oxygen sensor as well. Though I'm no expert on the subject. Limited experience. Once.
Anyone may feel free to disagree about O2 sensor. No, really.
Old Sep 3, 2015 | 10:05 AM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
X2 on the ignition advance. Mine would bog unless you were almost off the throttle.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
