What timming chain do I want to run?
Old Aug 3, 2015 | 01:47 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
356ci motor AFR # 1095 heads, xfi 224-230 570lift 112 cam, ls7 lifters, ported HSR intake swap in the works right now..... What chain do I want to run I need a part number. I want to make sure I'm getting the right one. Thanks guys
Old Aug 3, 2015 | 02:27 PM
Re: What timming chain do I want to run?
What block? (casting number only please)
Old Aug 3, 2015 | 02:36 PM
Car: 92 1500p\u 2wd
Where do I find this number. Back driver side says gm57lg and IO47.....its from a 91camaro I was told.
Old Aug 4, 2015 | 08:39 AM
Neither of those is the casting #.
It will be about a 7 or 8 digit #; the last 3 of that are enough. Might be 638, 880, 207, etc.
Unfortunately the sheet metal it was last wrapped in doesn't identify it unless known for absolutely certain that it originally came there.
Old Aug 4, 2015 | 11:00 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
May be a stupid question, but what happened to the original chain?
Old Aug 4, 2015 | 05:53 PM
Car: 92 1500p\u 2wd
Doing a head cam topend rebuild and want to replace the chain also.
And the block casting # is .... ??
Old Aug 4, 2015 | 06:10 PM
Car: 92 1500p\u 2wd
14093638. It's was hiding on the passenger side not the driver side...
Old Aug 4, 2015 | 07:11 PM
OK, should be a roller block then. Or at least, convertible to one.
Assuming you have (are buying) a step-nose cam and you have (will buy) a cam retainer and that your 638 is (will be) tapped for the "spider" thing to hold the figure-8 things of the factory roller setup and the factory cam retainer plate (one of them anyway, there are actually 2):
Cloyes 3145; there's a bunch of em, different prefixes suffixes letters numbers symbols etc., depending on how much bling you wanna bite off on. "Street", "original", "true", etc.
Comp 3136 is another reliable one. Probably what I'd go with to avoid having to decipher Cloyes' inscrutable marketing bull droppings.
Avoid the cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep chinesium junk no matter what else. CAT, no-name, "best price on ebay", etc.
Old Aug 5, 2015 | 07:18 PM
Car: 92 1500p\u 2wd
Will this fit under a stock timming cover and do I need to clearance the block for this chain to fit?
Old Aug 5, 2015 | 07:55 PM
May need to clearance the block; seems to be one of the "improvements" in those later-model blocks that has to be ... defeated.
Not sure about a "timming cover". Conjures up all sorts of strange mental images. Sounds like something we would catch Tim hiding underneath while he's committing an impure act. However, it will fit under a stock TIMING cover. Something quite different, I suspect.
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
MY87LT
Aug 17, 2015 08:43 AM
