starter or something else?
Old Sep 6, 2015 | 02:29 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
sometimes I turn the key and nothing happens until I try it bout 3 to 4 times then it starts. I mean no click from starter when I say nothing happens. other times I can get in it and it turns right over. vats has been bypassed.
Old Sep 7, 2015 | 12:42 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: starter or something else?
NSS (neutral safety switch)
Loose battery cable (+ or -)
Corrosion on battery posts or cable ends
Loose wire on starter
Old Sep 8, 2015 | 08:31 AM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Yes! the starter relay, drove me nuts also, exact same problem you are describing. It is located behind the kick panel next to your left foot.
I've enclosed a pick of it, hope I did this correctly. Easy to replace and should solve your issue.
Good luck
Old Sep 24, 2015 | 02:04 PM
mcbitchman's Avatar
Car: 84 s/e, 94 must conv, 66 must
Engine: 2.8 v6
Transmission: 5 speed manual
Axle/Gears: 3.42 posi just chngd from 3.73
Good luck
hello ,,, I've got the same problem w/ a 84 firebird v6 manual.... is there a relay on it also...??
Old Sep 27, 2015 | 05:55 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thanks for the replies. I put new starter on my car and haven't had anymore problems. I think the solenoid was bad in the old one.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
