Road race oil pan
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Road race oil pan
Does anyone know of a good 6,7, or 8 quart road race or drag race baffled type oil pan for our cars that is similar to the canton for a 1 piece block that is affordable. On eBay there are several that look very similar to the canton with trap doors but nothing saying what cars they will fit. Need one to fit stock exhaust and one piece rear main.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Road race oil pan
Canton sells a pan that meets all your criteria- and it's listed specifically for the third gen F body... or are you looking to buy a cheap knockoff so you can save a few bucks and know the joys of chasing oil leaks and think that is a good way to spend your time?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You can also run this and a tall filter. It will give you an extra Quart of engine oil and about the same with the transmission oil.
It's large enough to accommodate the 14in puller fan I have on it.
The transmission oil runs constant but the engine oil has a temp. controlled sandwich adapter that only lets it start to flow at 180*/operating temperature for my car.
Your going to need an transmission oil cooler anyway. Why not have both.
Don't let the tube and fin fool you, it has a total of 7ft of tubing for the transmission oil and 4.6ft for the engine oil and that does not count the long hoses for both. You can use either or for fluids. I chose to have the trans. oil in the longer run.
And its made in the U.S.A.
Link = http://www.summitracing.com/parts/der-15903
The 14in fan mounted on it is adjustable , temperature controlled an can be set to come on at what ever temperature I want.
Engine: 4++,350 & 305 CIs
Canton, pricey but worth it.
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
