Where does this vacuum line go?
Old Oct 10, 2015 | 01:56 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
On the attached image it's the one with the blue arrow/circle.
There are 3 lines coming off the canister here. One goes to the TB, one below that goes to a cylinder connector which branches out to other vacuum lines.
The last one here just seems to be venting, I can't imagine this is correct?
Old Oct 10, 2015 | 05:44 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Re: Where does this vacuum line go?
I have attached a 2nd picture. This is another i'm not sure where she needs to go. I have of those types hooked to the heater control valve and the egr valve.
It will reach all the way to the TB.
Any ideas?
Old Oct 10, 2015 | 10:06 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
This goes to the fuel tank via hard lines I think?? not 100% sure but I think so.
That looks to be the second vacuum tube from the egr solenoid that goes to the throttle body I believe.
Old Oct 12, 2015 | 05:18 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Update on this, I still can't find where the small line goes. I put a picture up of the area where 2 lines come up right next to each other. They are the more plastic feel lines. One is shorter and goes to the EGR valve and the other one is longer and reaches the TB. I don't see another spot to put it.
Any more thoughts or am I just missing this thing completely?
The 2 lines come up right by the MAP sensor and Distrib cap area.
Old Oct 12, 2015 | 05:21 PM
thtanner's Avatar
It should go to the TB.
The 2 hard plastic vacuum lines are from the EGR solenoid. Shorter goes to the EGR, longer to the TB.
Old Oct 12, 2015 | 05:35 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
What is the exact spot it plugs in thtanner? I must be blind.
kaupca
Oct 23, 2015 06:14 PM
knightinblackar
Brakes
Oct 13, 2015 05:26 PM
budowski
Carburetors
Oct 10, 2015 03:28 PM
Pbarnett98
Oct 8, 2015 05:24 AM
iroczguy86
Sep 23, 2015 01:19 PM
