Timing Chain Cover = PITA (have a few?'s)
Old Dec 20, 2001 | 01:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I put the cover back on after 90 minutes working on it. I got upset and grided the corners a little bit. I know it wasnt the best move but I think it'll be ok. Now my ? is Can i put some RTV around the bottom of the cover and seal so that incase and littel oil does get through it wont get through the barrier of RTV. I know it would look gay buy I am painting the block black and going to paint righ tover the RTV What do you guys sugg?
Old Dec 20, 2001 | 01:49 PM
gravitar's Avatar
you're taking a gamble by doing that, and I don't like your odds. If it were up to me, I'd get a different cover.
Old Dec 20, 2001 | 02:02 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Ground what corners? Are you talking about the lip on the bottom that wants you to have to drop the oil pain to get the cover back on? If so, I trimmed mine down. I have yet to see a drop of oil come out of there.
Yes, I know, there is a reason why they did that, but hell, that's what gaskets and RTV is for right?
Old Dec 20, 2001 | 02:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yup I grounded down the inner corners of the inside edge that goes behind the seal and into the pan. I know a friend did this and he doesnt have any leaks. I'm hoping it will be good. RTV is my friend.
Old Dec 20, 2001 | 02:24 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Yeah, man. I studied what adverse effects trimming that tab down would be and I didn't come up with any. Nice rubber gasket and a nice bead of RTV ... no problems. I don't recommend it ... I guess, but I didn't and don't have any leaks there.
Old Dec 20, 2001 | 02:32 PM
GRENDLE's Avatar
when i worked for ford, that was what the gm tech's across the parking lot said they do. they cut the inner lip at a 45 degree angle and rvt it good. use the black rvt and it blends in good also. they consider those "gravy jobs", i thought they were crazy till i found out why . they also said they do the cut the "trunk" fuel pump changes as well. i got my TA and looked , sure enough someone did it that way on mine too LOL
Old Dec 20, 2001 | 03:24 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Now the cutting the hole in the truck for the pump is one thing I don't recommend. I replaced mine the right way. Something about cutting into the lines with a metal blade hitting metal objects and making sparks .....
Yes, it was a PITA, but hey ... gave me a good chance to purge the tank, replace the shocks, install my catback exhaust. See? It's all good!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
