What would cause wet plugs ?
Old Nov 2, 2015 | 07:35 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
With a fuel gauge on my rail, it's registering at 38 psi while cranking. No start, so I pulled a few easy access plugs and they're wet as can be. Could the diaphragm in the regulator be bad ? The injectors are brand new Delphi's and don't have a 1,000 miles on them. I put a noid light on every injector and they show a nominal pulse on each one.
Old Nov 2, 2015 | 08:07 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: What would cause wet plugs ?
It cranks, no start. You got fuel. Your injectors are good. You have wet plugs, so the fuel is not igniting. Check coil, ICM, dizzy to make sure you have spark.
Old Nov 3, 2015 | 04:37 PM
djmarch's Avatar
Engine: 5.7 ltr.
Sorry, forget to mention in my initial post that I do have spark. (used a spark tester on #1 plug)
Old Nov 4, 2015 | 11:48 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Pull the vacuum hose off the regulator, gas in line? You need a good hot spark, as in a bright blue/white arc that will jump a 1/2 inch gap and make a crisp "snap" sound. Just because you have spark doesn't mean it is "hot" enough to light the fire. HTH!
3rdGenBirdOwner
Mar 3, 2016 09:03 PM
1nastyRS
Nov 1, 2015 06:26 PM
thelinux
Oct 31, 2015 11:30 AM
evan555222
Oct 30, 2015 02:44 PM
rode1951
Oct 30, 2015 02:52 AM
