Iroc will not Start
Old Nov 18, 2015 | 09:52 AM
SHELL929's Avatar
Car: 1989 Camaro Iroc Z
Iroc will not Start
Good day .
Here is the deal . I just purchase a 1989 Camaro iron z 350 5.7L with 91K on the clock . I notice the other day the check engine light came on and when the car is warm up and let say for example if I turn the car off and then try to restart it right way it will turn over for at least 30 sec and then start . Yesterday I pull the code using the paper clip and the only code I got was 36 maf burn off relay . today I replace the Maf relay and burn off relay . and now the car will not start at all. I put back on the old relay same problem will not start. I even replace the fuel pump relay because it look like it was old too and still no start. when i replace the relay I pull the battery cable out. Now I decided to see if there was another code just incase I missed one the first time and when I do the paper clip the check engine light didn't even come on not even the 12 code . Can anyone please point me to the right direction?
Thank you
Old Nov 18, 2015 | 10:07 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Iroc will not Start
Are you getting the 2 second prime when you turn the key to on?
Old Nov 18, 2015 | 10:36 AM
SHELL929's Avatar
Sorry how do you check for the 2 sec prime?
Old Nov 18, 2015 | 10:40 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Turn the key on to ACC and listen for the Fuel Pump to PRIME/RUN/BUZZ for 2 seconds
Old Nov 18, 2015 | 01:35 PM
SHELL929's Avatar
[QUOTE=Bob88GTA;5980911]Turn the key on to ACC and listen for the Fuel Pump
I didn't hear the fuel pump prime but I finally figure out what was the problem the fuel pump fuse was blown replace It and it the car runs
Old Nov 18, 2015 | 01:36 PM
SHELL929's Avatar
[QUOTE=SHELL929;5980959]
thank you for your help you
Old Nov 18, 2015 | 01:51 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Glad to hear.
Zylinder
Oct 14, 2016 01:08 PM
gunznrosez87
Oct 14, 2015 11:56 PM
L98GTA87
Oct 14, 2015 08:35 PM
MSRed91Camaro
Carburetors
Oct 7, 2015 08:31 AM
L98GTA87
Exterior Parts Wanted
Oct 3, 2015 06:14 PM
