Annoying issue
Old Dec 7, 2015 | 07:38 PM
PonFirebird's Avatar
Annoying issue
Hi guys I have a 1987 pontiac firebird formula 350
And since I've owned it's all ways felt down on power then one day it gained alot of power the fell flat and check engine light came on and engine temp rose read fault codeand was 02 sensor have since replaced sensor for a 3 wire one and car is still down on power and struggling to rev past 3000
And again gained power once a week later and same issue happened I've checked all injectors and they are showing 16 ohms cold so who has any clues on where to start looking
Old Dec 9, 2015 | 06:00 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Annoying issue
If you can't reve much past 3k I'd be looking at my ignition stuff.
Old Dec 9, 2015 | 07:08 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Annoying issue
Cat clogged maybe (if it's still on there)
Old Dec 9, 2015 | 03:51 PM
Re: Annoying issue
It will rev past but very slowly and struggle like it's hitting a brick wall
Old Dec 9, 2015 | 03:52 PM
Re: Annoying issue
I've pulled cat off and there is nothing in there at all its hollow apart from one small pipe running through it
Old Dec 9, 2015 | 04:52 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Annoying issue
Checked for any other codes? Could be a lot of things, but if it comes and goes like that my guess is EGR probably sticking.
Old Dec 9, 2015 | 11:16 PM
Re: Annoying issue
Only code that shows is code 13 which is 02 sensor
Old Dec 13, 2015 | 12:02 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Annoying issue
Sounds like its not advancing.. Hitting a brick wall....
John1987formula
Apr 13, 2020 09:58 PM
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
Iroc_Lopez28
Nov 10, 2015 06:54 PM
Jacques101
Nov 8, 2015 04:43 PM
irockinit
Nov 8, 2015 02:29 PM
