headlight switch problems
Old Dec 12, 2015 | 04:35 PM
ladykriptonite's Avatar
Car: 1986 chevy iroc camaro
Engine: 350 corvette
Hi i had someone replace my headlight switch now whenever i turn on my headlights all my gauges (except speedometer & gas) go crazy then dont work. Switch to bright lights headlight start blinking off & on.
Cant afford a visit to mechanic shop right now but i can work on my 1986 iroc myself if i know what to look for or do to it. Do you think its a grounding problem or maybe relay problem pls help thank you.
Old Dec 16, 2015 | 01:34 PM
Destro Camaro's Avatar
Car: 88 Camaro
Engine: 2.8 V6 For Now
Re: headlight switch problems
My first guess would be a grounding problem. What I have learned about these cars that bad grounding makes everything act crazy.
If that do not correct the problem I would look online for the wire diagrams for your car and make sure the person who installed your light switch done everything correctly.
Old Dec 17, 2015 | 10:36 AM
I will check that stuff out. Thanks for the advice
Maro86Z28
Jul 2, 2017 09:57 PM
Chris Luongo
Aug 23, 2016 08:58 AM
rayoki06@gmail.
Feb 17, 2016 12:37 PM
LarryD
Dec 10, 2015 02:33 PM
SHELL929
Nov 18, 2015 01:51 PM
