RPM reader
Old Dec 16, 2015 | 02:28 PM
db057's Avatar
RPM reader
Have a question, honestly not sure. I understand the TACH's tend to read high (or can). even though this Camaro reads higher, and my other Camaro I had (same year, engine, etc.) never had that problem.
Is there a way to externally check the RPMs outside of the tach itself? Like a timing light (not sure how accurate) with some digital RPM reading? or an code scanner that can digitally read the RPMS (outside of the flashing engine codes). or anything? just wanted to see where I am at, especially since I had adjusted the base idle and if it's not reading right, than I may just be adjusting it wrong. appreciate it. thanks!
Old Dec 16, 2015 | 05:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: RPM reader
A scan tool on the ALDL link is accurate.
RBob.
Old Dec 16, 2015 | 09:37 PM
Vader's Avatar
Re: RPM reader
A standard diagnostic tachometer is usually all you need.
Old Dec 17, 2015 | 01:30 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: RPM reader
Timing light with RPM read out works. I have this one
Amazon.com: INNOVA 3568 Digital Timing Light: Automotive Amazon.com: INNOVA 3568 Digital Timing Light: Automotive
I had it for close to 10 years now. Been a great timing light/RPM gauge. I use it all the time really. As far as testing tools goes this and a DVOM gets the most use in my shop.
A diagnostic tachometer would work as well, like a tach/dwell meter
Amazon.com: Actron CP7605 Dwell/Tachometer/Voltmeter Analyzer: Automotive Amazon.com: Actron CP7605 Dwell/Tachometer/Voltmeter Analyzer: Automotive
AirwolfPL
Mar 19, 2017 06:53 PM
Knight Prowl
Exterior Parts Wanted
Dec 7, 2015 10:40 PM
bbsr72
Nov 13, 2015 08:21 AM
F-Jape
Oct 31, 2015 12:05 PM
TipTricky
Oct 27, 2015 03:17 PM
