305 LT1 intake and heads
Old Dec 21, 2015 | 02:45 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Hi,
I'm in the process of building 305 with LT1 heads and intake that are actually ready to be installed - did all conversion stuff. but i can't figure out which cam and why i should choose. LT1 heads are with 2.00/1.55 valves so propably limited with lift to like .440/.450 or even less? Any help or ideas ? My goal is to make 305 with LT1 heads (small bet with my friend) and reach atleast 305 at crank.
best regrards
Old Dec 21, 2015 | 07:46 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: 305 LT1 intake and heads
I think Lt1 heads can take a lot more lift, I believe it was around 550. The lt4 hotcam is 525 and it doesn't require any modification if I remember correctly
Old Dec 21, 2015 | 09:54 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
But on a small 305 bore the valves are dangerously close to the cylinder walls. I have no idea how close everything is with 2.00 valves considering 1.94 valves are close. Never measured it out myself, I don't know if I'd advise on using those heads on a 305.
Old Dec 22, 2015 | 02:27 AM
WASyL's Avatar
ME Leigh had LT1 heads on 305 but he does not visit TGO anymore so no contact with him, this is why i'm looking for help here.
Hotcam is one i consider to use.
best regards
Old Dec 22, 2015 | 08:31 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
It's unfortunate that those heads have the bigger valves. Besides the bore clearance issue, the stock 1.94/1.50 combo would probably flow better due to less bore shrouding. Unless of course your heads are ported also.....then you'll more than recover the shrouding loss. Consider fly-cutting the top edge of the bores to help things.
305 fwhp will be a walk in the park no matter what cam you choose, as long as your intake and exhaust doesn't restrict it. What's the vehicle application....weight, gearing, trans, TC stall, tire size, daily driver, drag, roadrace...? desired rpm power peak? rpm limit?
Old Dec 22, 2015 | 09:41 AM
WASyL's Avatar
It is Stock weight 3rd gen, LT1 intake with 2x52 TB, long headers, de-cat with flowmaster exhaust, 2100 TC, 3.32 gears, th700, all controled by Megasquirt, daily driver on 255/60/15 tires. As ia mentioned above i seek for 305 HP before hitting 5000RPM on crank, if more power is more then welcome
best regards
Old Dec 22, 2015 | 11:12 AM
86LG4Bird's Avatar
Before I spend too much time replying, please clarify that "5000RPM" is not an error. If you're serious about that, then the Hotcam is way too much.
Old Dec 22, 2015 | 02:38 PM
WASyL's Avatar
well if i'll be able to get more power then good, if that is not possible then this is why i'm here to learn what is possible and how.
best regards
Old Jan 14, 2016 | 01:53 AM
WASyL's Avatar
my heads are 2.00/1.55 valves casting 10128374, block is 0.020 bored, after measuring max valve lift i can go as much as 0.500" on intake and 0.525" on ext lift
best regards
Old Jan 14, 2016 | 06:12 AM
86LG4Bird's Avatar
best regards
Are you planning to run the stock springs and retainers? You really should upgrade to make use of any decent cam. Plus, the modified retainers that come with the better kits will allow at least .550" lift, which opens your cam options tremendously. Example: http://www.alexsparts.com/lt1-valve-...s-spring-base/
If you want to use your stock retainers, you can grind .050" or so from the bottom of the retainer to increase clearance to the valvestem seal at max lift; google "ghetto grind".
What's the compression ratio going to be? deck clearance, head gasket thickness, head chamber cc?
Old Jan 14, 2016 | 12:53 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
people actually go thru the effort of putting LT1 heads on a 305?
why? in the end, it's still just a 305..
Old Jan 15, 2016 | 03:29 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
You will have to max out your cam choice to hit 300whp. The LT1 doesn't make hp like the TPI makes torque or the LS1 makes hp. It's a blend of the two.
I had a cam only LT1 make 325whp with headers/rockers/EWP and a ****-poor tune. But that's 350 cubes. You'll need to maximize the bolt ons to hit your number.
Most Cam only LT1s with their 350cc dyno 320-360whp. 360 being T56s and every bolt on you can think of. Autos are almost all below 340, and again with 350 cubes.
Good luck.
Why do you wash your car? in the end, it's still just a camaro...
Old Jan 15, 2016 | 06:55 PM
86LG4Bird's Avatar
He specified 305 hp at the crank. Making that will be about as difficult as falling out of bed.
Old Jan 16, 2016 | 12:58 AM
Engine: LB9
Axle/Gears: 3.08
Look at that. Don't understand people who talk about crank numbers. So few engine dynos used in aftermarket.
Old Jan 16, 2016 | 03:56 AM
WASyL's Avatar
well, friend of mine have engine dyno so that is not a problem just 5 kilometers trip. as for cam i will go with this one http://www.summitracing.com/int/parts/lun-10120304lk/ (i have non roller block) and only thing i'm not sure of are stock LT1 springs will handle it? guideplates will be installed.
planing to advance the cam on timing chain 2 degrees
as for 0,050 spring install i do have these lock on the shelf just in case.
compresion will be around 9,5, pistons are flat top with 4 valve reliefs, 58cc heads (will check after resurfacing), gasket is 1,5mm before head install.
best regards
Old Jan 16, 2016 | 07:16 AM
86LG4Bird's Avatar
best regards
WASyL, that cam would be a huge mistake, given your VERY mild TC and gearing, and your 5000 rpm target. It will win your dyno bet, but will be useless in the car,.....and IF it holds together to 6500 rpm to even see its power peak. You should be targeting a cam with 264-270 deg intake duration (212-218 deg at .050" tappet lift). Even less if you want to limit it to 5000 rpm. And....you'll probably lose your dyno bet if you're not willing to rev it beyond 5000.
Oh....and stock LT1 springs will not control that cam to reach its powerband. They will, however, be adequate for the milder cams I mentioned. When new, they are good to about 5500-5700 rpm in the LT1 engine.
Old Jan 16, 2016 | 10:12 AM
WASyL's Avatar
ok, i'll get better springs then, any suggestions which to choose ?? gears and TC will be replaced around july
best regards
Old Jan 16, 2016 | 11:15 AM
Engine: LB9
Axle/Gears: 3.08
Hot cam springs are cheap and adequate.
Old Jan 16, 2016 | 11:38 AM
86LG4Bird's Avatar
Forget about using that 290 deg Lunati cam. It's strictly a drag race cam for high compression, steep-geared race cars with bigger cube motors. Horrible choice for your car. The most aggressive I would go in that Lunati line is this one: http://www.summitracing.com/parts/lun-80350lk/overview/ It would peak about 5800 rpm in your 305 with the short-runner LT1 manifold.
Here are some other options suited to 305 flat tappet engines, but they will make less power than the "265" Lunati I linked: http://www.summitracing.com/parts/su...make/Chevrolet
Add about 800 rpm to their "basic operation range" to account for your LT1/305 as compared to their dual-plane/350 assumption. Your stock LT1 valve springs will be good for those mild flat tappet cams.
Old Jan 16, 2016 | 11:41 AM
WASyL's Avatar
these ?
http://www.summitracing.com/int/parts/nal-12551483
best regards
Old Jan 16, 2016 | 01:12 PM
WASyL's Avatar
i've run my setup on desktop dyno and if i inputed everything correctly (cam advanced 4 deg) then is should be something around this
so not that bad
best regards
Old Jan 16, 2016 | 03:42 PM
86LG4Bird's Avatar
What cam is that?
Old Jan 17, 2016 | 04:53 AM
WASyL's Avatar
the one You said is way to big, oh and i just found out my friend is selling 4.11 gears so i bought them
best regards
Old Jan 17, 2016 | 06:15 AM
86LG4Bird's Avatar
best regards
You're obviously not putting the correct parameters into desktop dyno. LT1 manifold is single plane.
Regardless, DD is a cool toy to see the effect of changing a parameter or two, not to spec an engine, especially when you don't fully understand every input's effect.
You're either a troll or just stubborn. You're obviously not here for help, so I'm done. Good luck
Old Jan 17, 2016 | 11:08 AM
novaderrik's Avatar
Car: 86 Camaro
i rarely wash my Camaro- maybe once a year, and only if i decide to go do some hooning on gravel roads the day after it rains and i don't want a steady stream of sand and gravel falling on me when i change the oil or something..
to wash it more often than that makes about as much sense as putting an LT1 top end on a 305 instead of just swapping the whole damn thing in..
Old Jan 17, 2016 | 02:36 PM
WASyL's Avatar
swaping LT1 top is much cheaper then to find 350/LT1 in good shape in my country
best regards
IROC-BOB86
Dec 30, 2020 01:55 PM
mrestrictrplate
Alternative Port EFI Intakes
Apr 19, 2016 10:54 AM
FiVe KiLLZ
Dec 9, 2015 07:40 PM
MXCamaro
Dec 5, 2015 12:01 AM
Rocket-Doc
Nov 30, 2015 10:54 PM
