A lot of smoke and green fluid leaking
Old Jan 11, 2016 | 09:59 PM
jorgeblancojr's Avatar
My engine hydrolocked with fuel about half a month ago. Today, I finally got the car running since then.
I changed the Fuel Pressure Regulator, spark plugs, and the oil, then boom it started.
Now that it turned on and it's running it's throwing out a lot of smoke from the tail pipes and engine. It's also leaking a green fluid near the transmission.
What do i look at? What could the problem be now? Thanks in advance.
Old Jan 11, 2016 | 10:06 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: A lot of smoke and green fluid leaking
Blown head gasket or cracked head. Green fluid is coolant. Motors done
Old Jan 12, 2016 | 06:47 AM
Yup.
Green juice = anti-freeze
Looks like it toasted a head gasket. Time to pop the heads off and look inside. Might be a broken casting (block or head); let's hope not. Only one way to find out, and that is, take it apart and look.
Old Jan 12, 2016 | 07:13 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
GOOD LORD! Really????????
Old Jan 12, 2016 | 08:27 AM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
From the looks of all that moisture on the bell housing it looks like something has been leaking a while...
soarestransam
Feb 1, 2016 04:12 PM
middian
Dec 21, 2015 05:46 PM
WickedBowtie
Fabrication
Dec 19, 2015 09:16 AM
WVmotorhead
Dec 17, 2015 11:59 AM
racerx520
Dec 14, 2015 12:29 PM
