new afr heads installed no change in power vader?
Old Dec 22, 2001 | 10:19 PM
chrisfrerick's Avatar
i had my motor completely rebuilt and had afr 190cc heads and crane rockers installed and it doesnt seem any faster then it did before with the factory heads. what could the problem be? other mods listed below.
Old Dec 22, 2001 | 10:52 PM
Momar's Avatar
Did you up the compression for alluminum heads or did you leave it the same?
Old Dec 22, 2001 | 10:57 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, have you burnt a new eprom to take advantage of those new heads? AFRs can generally handle a lot more spark advance than stock heads, and that is key to making more power.
Also, that TPI intake is probably not helping you as much as you could with a Superram or Miniram. What about the cam?
Old Dec 22, 2001 | 10:58 PM
the heads were supposed to be kept to factory specs as recommended by afr. i beleave they milled them to 64cc.
Old Dec 22, 2001 | 11:02 PM
rezinn's Avatar
Perhaps when the motor was rebuilt the timing was set back to stock? Have you checked that?
Old Dec 22, 2001 | 11:21 PM
i know for a fact the timing was set back to factory settings at 6 degrees. would that make that much of a difference? does anyone know what the slp cam timing should be set at?
i have a thermomaster chip would a custom chip be better?
i also have an adjustable fuel regulator and i told him to set it at 50psi he might of changed it back to a lower setting.
Old Dec 23, 2001 | 02:02 AM
lancer5067's Avatar
I belive in the KISS method of troubleshooting:
1. do you have optimum compression (aka new properly installed head gasket?)
2. new spark plugs (or even a spark in all cylinders?)
3. cylinders recieving proper amount of fuel
4. timing was already mentioned
5. operable maf/O2 sensors
if everything is on track look at the rest of your mods, your intake side kicks @$$ but your rear end gears and exhaust (except headers) are killing you.
The rest is politics. Good luck!
Old Dec 23, 2001 | 02:20 AM
rezinn's Avatar
I'd say give it more timing and check how it is running fuel wise, definitely check the plugs.
Old Dec 23, 2001 | 02:39 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
when are the gears getting installed??? whats the fuel pressure set at??? what is your base timming??? with your current mods you should notice an improvement but, your mods with those gears you are not going to get the performance you want...
zroc
Old Dec 23, 2001 | 08:01 AM
Car: Death Mobile
Engine: 666 c.i.
Oh yes. I also notice the comments about "changing the timing back to 6*". This is NOT the way to advance the timing on an EFI car. It should be done within the eprom.
Just advancing your timing say 4* can trigger knock retard in areas where the engine cannot tolerate it (such as lower rpms before peak torque). Once detonation occurs (whether audible or not), you performance is killed.
Basically, you need the spark advance to start building just before peak TQ to max HP, along with a mixture somewhere between 12.6-13.1. Those AFRs should probably make max power somewhere around 34-36* near peak TQ. Most of the stock eproms for GM cars have the max timing occuring somewhere around 28-30* with up to 12* of knock retard at the slightest hint of detonation.
Remember also that the your peak TQ is occurring at different points most likely with those heads, so where you're max timing is going to occur is also going to change.
If you were to talk to a "racer using a carb" about your swap, he'd recommend you change the "curve" in the distributor to get max HP to match the new heads. EFI is even more particular - "mechanical fixes" are not the answer. You have to do it inside the eprom.
Old Dec 23, 2001 | 10:39 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Also how amany miles do you have on this rebuilt engine? I just rebuilt a 350 and droped it into the firebird last month and it took over 500 miles before that sucker loosend up, 780mi.
SSC
Old Dec 29, 2001 | 09:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
