Engine spec unknown
Old Feb 24, 2016 | 10:30 AM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Engine spec unknown
I have 5.0 TPI that's in a 88 model Firebird auto with 3.23 gear. Engine has been rebuilt by previous owner when I found him on a site and ask him all he would say is It's got pistons and cam and very good stuff and dropped off not to tell no more than that. The car is strong and is pulling 0-60 around 6.6 sec and pulls hard up in the 5000 rpm range . Anybody got a idea of what he may have done to this engine?
Old Feb 24, 2016 | 12:45 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Engine spec unknown
Go test it in the 1/4 or put it on a dyno and that could give us an idea. Its probably stock.
Old Feb 24, 2016 | 01:37 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Ok will do thanks
Old Feb 24, 2016 | 01:41 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
He put a lot in the suspension. It's low and all under side is new. I got a bad vibration due to the lowering so I'm thinking about seeing if some one will trade me for stock springs.
Old Feb 27, 2016 | 12:46 AM
Night rider327's Avatar
Car: 1988 Camaro
Are they aftermarket lowering springs, or factory springs that has been cut? If they are aftermarkets, I will trade with you. I have 3 or 4 sets of factory ones. (I part out third gens) and I'm in GA. as well.
Now as far as your car. Hard to say what the PO did. Get part numbers off of parts, casting numbers off the heads, etc. Do a compression test, leak down test. Put a bore scope in the spark plug holes to try and see what pistons are in it. Use a dial gauge to check valve lift, and a degree wheel to get close on the duration
Old Mar 1, 2016 | 10:00 AM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
There aftermarkets purple sport line
Old Mar 1, 2016 | 07:01 PM
Car: 1988 Camaro
Yeah I will trade with you if you want. I have sets from an 84 and 85 Z28, 87 firebird v8, 89 formula, 84 trans am
jonarotz
May 25, 2017 11:07 AM
Richard Tuisk
Members Firebirds
Feb 13, 2016 11:31 AM
articwhiteZ
Feb 3, 2016 12:16 PM
Abubaca
Jan 27, 2016 09:12 PM
1988_f-bird
Jan 26, 2016 09:53 AM
