383 stroker build
Old Feb 24, 2016 | 07:44 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
383 stroker build
Ok here's the dilema I am putting together a 383 stroker for the TA and I'm torn on what heads would work best for my set up. My friends have thrown some options at me, but I want to make sure what I am going to get is going to be what works for me. So if any of you motor experts could throw some advice my way I would appreciate it.
Here's my set up so far. I have a gen 1 SBC bored .40 over. It's an Eagle steel Rotating Piston Crank Assembly Kit with forged dished pistons and H beam rods. The cam is a solid roller with 660/630 lift. (Will post the cam card when I can.).
Ok now that is out of the way I want to pick up some heads. I am leaning towards a pair of AFR's for around $1,700ish. Another dilema I am looking at is I did the set up so far with intentions to at some point add a vortech supercharger kit next income tax season. So that's why I want to get the heads right so that when I'm ready for the vortech I dont need a different set of heads all over. Also while I'm at it if anyone has some recommendations for the intake/carb let me know. Thanks in advance for the tech help.
Old Feb 24, 2016 | 10:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 stroker build
How much power you want? Stock block i wouldnt push more than 800 with splayed main conversion.
Afr 195's will do that
Old Feb 25, 2016 | 03:02 AM
Slayze's Avatar
Car: 87 Trans Am
I'm not looking to go over 800 hp
Old Feb 25, 2016 | 07:03 AM
Slayze's Avatar
Car: 87 Trans Am
Heres the cam. Also when you said "AFR 195's will do that" I was actually looking at something higher. From what people have been telling me I dont want to go under a 210. You feel 195's would do the trick?
Old Feb 25, 2016 | 07:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Lol dont need anything over 210 on a little 383. I ran 195's on a 400 and ran 9.7-9.8's on just 14 psi. 640-660 whp on a mustang dyno
I ran 195's on a 7000 rpm 383 on a 150 shot, 520's whp. 10.6's at 128
Old Feb 25, 2016 | 07:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I think that cam is big for what you want and need. Lsa is also tad tight imo for what you need. Cam would fit a 210-220 heads rpm potential tho but its a 1000-1200 hp setup easily
Old Feb 25, 2016 | 09:23 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Agreed. That's a wicked nasty cam for a serious NA engine. It has no business on a FI setup.
Old Feb 25, 2016 | 09:31 AM
Slayze's Avatar
Car: 87 Trans Am
FI set up as in fuel injection? I going carb not FI.
Old Feb 25, 2016 | 09:41 AM
Slayze's Avatar
Car: 87 Trans Am
Here's the heads I was looking at.
http://m.summitracing.com/parts/afr-1050
I know the cam is a tad over the top, but the price I got the solid roller and lifters for I couldn't pass it up. I figured I could work with it. Also here is the vortech kit I was eventually looking at getting.
http://www.jegs.com/i/Vortech/933/4G...j7XBoCfTDw_wcB
So with the links and info I have given so far do you think I should go with a smaller head?
Old Feb 25, 2016 | 09:42 AM
86LG4Bird's Avatar
Forced Induction. ie. Supercharged.
Fuel injection in the hands of a competent tuner can handle anything a carb can handle.
Old Feb 25, 2016 | 09:45 AM
Slayze's Avatar
Car: 87 Trans Am
Ah OK thought you meant fuel injection
Old Feb 25, 2016 | 09:46 AM
Slayze's Avatar
Car: 87 Trans Am
So you think I'm better off not running the vortech with the set up?
Old Feb 25, 2016 | 09:56 AM
86LG4Bird's Avatar
I won't candy coat this.......I think you have no understanding of what you're trying to do, and you should not buy another single part until you have a workable plan. Right now it's not even close.
How do you plan to use the car?
Forget about using that cam at all. It would be suited to an engine much larger than 383 ci and revving to 8000 rpm. If you use the car at all, you'd probably spend $1000-$2000 annually on valvetrain maintenance/replacing parts!
Ultra-high compression ratio. Race fuel only. ........
Old Feb 25, 2016 | 10:06 AM
SR71BLKBRD's Avatar
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
I second Orr. Def knows what hes talking about.
The competition ported 195's would prob be spot on. Also why dont you call around and talk to whichever cam company you're interested in going with and have them make you a custom grind for exactly what you want to do with the car. I wish I would have.
Old Feb 25, 2016 | 03:17 PM
Slayze's Avatar
Car: 87 Trans Am
The cars used mainly for car shows. I never ran it down the track though I wanted to just never got around to trailering it to the track. Really only reason i wanted to take it to the track was to see what time I could get in the 1/4.
I appreciate all the replies and the suggestions, but unfortunately the shop already assembled the bottom end. So I'm definitely going to keep checking into the current set up. I contacted AFR to see what they recommend. Still waiting on a reply.
I'm gonna exhaust all efforts to salvage what I have already put together before I go yanking anything back out.
Old Feb 25, 2016 | 07:20 PM
In a general way, using The Force reduces the significance of mechanical changes to the motor (head port size etc.). Note that I said REDUCES, not ELMINATES.
This works in somewhat analogous ways to high-speed handling (NASCAR / F1 / Indy car/ etc.) of adding aerodynamic downforce... the more of that you have, the less difference mechanical grip makes. Who cares about fine-tuning effects on the order of 50 lb from optimizing left front tire grip, when you have 2000 extra lbs of aero downforce. Forced induction works similarly: intake port size IN PARTICULAR loses much of its significance, whereas exhaust port size ends up becoming The Bottleneck.
Sounds to me like in an overall sort of way, you need to develop a better understanding of what makes engines work, and where their limits are, and how to better evaluate the various effects involved.
OTOH...
makes it sound to me like you just need to go the junkyard and pick up some old 305, or maybe buy the phone company van motor from GM (the "260 HP" POS) if you don't feel like getting too dirty in the process, and become best buddies with somebody that owns a chrome-plating business, and another with an aluminum-polishing one; and FORGET all this crap about "what heads" and all that. Just jam a 6-71 blower on it, maybe acoupla turbos (why not 3? just chrome em, doesn't even matter if they're plumbed to either the intake or the exhaust, as long as they're BIG and SHINY), a fogger kit, and a hood with a BIG hole in the middle. As long as it runs enough to pull itself onto the trailer, almost, that is as long as you can put like a small inconspicuous boat trailer winch on there to "help" it, what difference does it make about "heads".
Sorry, unlike LG4Bird, I felt like candy-coating the truth a bit.
Old Feb 27, 2016 | 10:43 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you are going to use a forced induction setup you need a forged crank, do you have forged or cast steel? The compression ratios for forced and natural are very different also. Any decent NA street cam will want at least 10:1 where as forced may only want 8:1 So you could use either the same pistons and change heads when you get around to putting a blower on it or use the same heads and change pistons. It really sounds like you are in over your head, I would second a version of what Sofa is saying. Purchase a new short block and just add all the chrome or polish aluminum parts to it. You'll never be drag racing it as a hobby and you'll probably make 300 horsepower to the wheels (as long as you use decent parts) which is enough to have fun driving it.
Old Feb 27, 2016 | 12:00 PM
Slayze's Avatar
Car: 87 Trans Am
It is an eagle forged crank and dished pistons. Thanks for the replies.
Old Feb 27, 2016 | 02:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
If they are dished it sounds like you'll be building a forced induction motor. You'll be driving a low compression engine that won't make much power until you get the supercharger on. Using one cam before the supercharger and one when you have it will help some.
Old Feb 27, 2016 | 04:22 PM
Slayze's Avatar
Car: 87 Trans Am
Yeah forced induction is the plan.
Old Mar 10, 2016 | 04:14 AM
Slayze's Avatar
Car: 87 Trans Am
AFR's recommendations as per the build:
You should look at our 210 Eliminator head. Our 210 head delivers a significant upgrade supplying superior airflow while maintaining velocity for broad torque and stout power; generating quick throttle with mid-range & top-end performance. Be advised, our 210 head is equipped with a 2.080” intake valve. Contact your piston manufacturer to confirm radial clearance with their valve relief.
Please call if you have any questions or require further technical assistance.
Old Mar 10, 2016 | 07:36 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
"while maintaining velocity". Nice. I am torn between AFR 195's and AFR 210's in my 383 build as well, possible nitrous. It will be the last major purchase. Keep us updated!
Old Mar 10, 2016 | 08:34 PM
86LG4Bird's Avatar
It's a no brainer for any healthy 383 - go with the 210's
Old Mar 11, 2016 | 12:15 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Disagree. You can go either way, just depends what you will do with the car but if you are putting a super or turbo charger on go with the 210.
Old Mar 11, 2016 | 06:29 AM
86LG4Bird's Avatar
Well, UltRoad, I guess you should tell us: Are you building a "healthy" 383 which would want 210 heads? or a lower rpm, small cam, tight TC, highway geared 383 that would want 190 heads?
FWIW, I run 200cc heads on a 350 CID motor in a 3800 lb car. It has more low end than street tires could ever handle, 60's in the low 1.4x's. I sure wouldn't want anything less on a 383!
Old Mar 11, 2016 | 07:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Power adder go bigger
Old Mar 11, 2016 | 12:09 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Numerous 383 articles using 195 heads making good numbers along with members on here making good 1/4 mile times, their results beg to differ with you . AFR, Tony Momo, Trick Flow and Howards Cams even say you can go either way depending on what the engine will be used for. Maybe years ago you needed 210s to get decent flow but not today's heads.
Old Mar 11, 2016 | 12:15 PM
86LG4Bird's Avatar
... you can go either way depending on what the engine will be used for.....
I don't see an argument here
Old Jul 17, 2017 | 08:43 PM
Slayze's Avatar
Car: 87 Trans Am
Ended up going a little smaller on the cam. .604/.602 and a set of procomp heads. It's running strong. I don't think I am going to put any supercharger on yet since it's running good without it.
Old Jul 18, 2017 | 05:51 PM
Car: 1986 IROC Z-28
Congrats on the build
Were the AFR's too much compared to the procomp's? What intake runner size?
Old Jul 18, 2017 | 07:09 PM
Slayze's Avatar
Car: 87 Trans Am
Yeah a guy I know got me a set for a little over $800. 190 intake runner. I'm happy with how it came out so far.
Old Jul 19, 2017 | 09:55 AM
Car: 1986 IROC Z-28
Keep us updated on how you like solid rollers for street. I'm on the fence about those right now for my build, but they're looking better all the time.
Old Jul 19, 2017 | 10:29 AM
Slayze's Avatar
Car: 87 Trans Am
So far I like it, but it's not a daily driver so I can't speak for daily street driven. Cam I got from http://www.herbertcams.com I really enjoyed being able to call these guys up and tell them my set up and have them give me some recommendations on what would work for me. They also have .900 base circle I needed for the stroker. If you decide to go solid I would include them in the search for a cam.
Old Jul 20, 2017 | 11:57 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Sounds nasty, love the solid rollers. Use premium valvetrain equiptment and they will last just fine. Not as long as a HR but who puts even 30k on a toy? Usually sell them or get bored and do something different anyways long before then
Just dont buy cheap lifters, pushrods, etc.
OP what carb and jetting did you wind up with, curious
Old Jul 24, 2017 | 06:38 PM
HINKSON AUTO's Avatar
You used the wrong rods if you needed to go to a .900 base circle, Roller lifters hate reduced base circle cams, This build was not planned out very well.
Old Jul 24, 2017 | 07:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup. I ran a standard base circle that seemed to measure around 1" base with eagle h beams. .376/.383 lobe lift.
Then ran another around same base measurement, .352" lobe, with callies compstar h beam. Then ran a .400" lobe lift on same callies rods. I dont think it was a small lobe. Being big lobe lift, it likely measured in the .990's range just a guess.
Old Jul 24, 2017 | 09:30 PM
3.750 stroke and Callies Compstar or Ultra rods and BBC cam journal .060 plus clearance.
With this build I would go with a better block or at least splayed center caps and sonic test is a must. Hope he spent money on plate honing or to much blowby will burn right down the side of the pistons,
Old Jul 25, 2017 | 03:13 AM
Slayze's Avatar
Car: 87 Trans Am
They are 6" rods and as far as the lifters they are crane lifters with the spring-loaded horizontal guide bar setup. The lifters don't don't even touch the base circle till they see lift.
As far as this not being well planned out build as you say I did the best I could with it being my first 383. It's running strong so far. If I did do something wrong time will tell and lesson learned. Thanks for the input though.
Old Jul 26, 2017 | 05:32 PM
Slayze's Avatar
Car: 87 Trans Am
Old Jul 27, 2017 | 12:17 AM
NoEmissions84TA's Avatar
WHAT???
Old Jul 27, 2017 | 03:16 AM
Slayze's Avatar
Car: 87 Trans Am
WHAT???
Yes, the lifter is held off of the camshaft by the spring on the horizontal bar until lift.
That horizontal bar lifts it off the cam so you can change cam without taking intake off.
Old Jul 27, 2017 | 07:09 AM
  #42
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats only when the rocker arms are not tightened down. The valvespring most definitely keeps lifter on the lobe at all times else you'd have wiped cam lobes and lifter damage in no time at all
Old Jul 27, 2017 | 07:25 AM
  #43
Slayze's Avatar
Car: 87 Trans Am
I thought the same. That's why I went back and forth with crane (see email screen shots).
usmechanix
Theoretical and Street Racing
109
May 17, 2016 04:20 PM
broke91firebird
Feb 3, 2016 04:10 PM
hereinmissoula
Jan 31, 2016 01:28 PM
shiftngo
Jan 26, 2016 11:20 PM
bonesbrakr
Jan 26, 2016 06:50 PM
