Oil Pan Suggestions
Old Mar 8, 2016 | 01:01 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Oil Pan Suggestions
Would like to get a few opinions on oil pans, and pickups for a Friday Night Bracket Car....Do not have any at all right now, and can go Junk Yard, or Aftermarket..I dont mind paying a bit for a little added safety margin...Car is an 89 RS, 350 CI 6200 max.....I ran a Moroso 7qt on my BB Chrysler with a larger pickup and Windage tray never had oiling problems...Thanks...
Old Mar 8, 2016 | 01:11 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Oil Pan Suggestions
What is your anticipated 60' time?
Will you be very hard on the brakes (limited shutdown area)? If you're running front skinnies, then I don't anticipate this will be an issue to worry about; they will limit the extent that your oil sloshes to the front of the pan
FWIW, I ran a stock pan on my Impala for 6 yrs, pulling 1.4X 60's, wheels up launches, and never had an oil pressure issue. Front skinnies.
I'm not sure if your pan has the same provisions: windage tray + baffle behind the pump to keep oil from crawling the back of the pan on launches.
To eliminate all doubt, run something like this:
http://www.jegs.com/i/Moroso/710/201...oductId=763973
Old Mar 8, 2016 | 01:57 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
86 thanks for the advice...The car does have skinnys on the front, and currently tall (too tall for the gears) drag radials...I do not know what the 60' will be as this is an entirley new motor, plus the car has went on a diet...With the 305, I ran the stock pan with a windage tray in it, and a white spring (iirc) in the pump...That seem really good for a full size Impala, once again thanks....I would rather ask, than regret it later.....Tom
Old Mar 9, 2016 | 01:07 AM
Night rider327's Avatar
Car: 1988 Camaro
I use a summit racing 7 qt kicked out sump pan with matching pickup.
Speedway motors stainless windage screen
Rear main oil baffle
Old Mar 9, 2016 | 07:30 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks Night
Old Mar 12, 2016 | 08:12 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I went with this oil pan and have been happy.
http://www.summitracing.com/parts/su...make/chevrolet
Old Mar 14, 2016 | 02:49 PM
Andy-Z28's Avatar
Car: 1982 Z28 #7X25
Engine: 383, 750 carb, long tube headers
Transmission: TCI TH350, 3000 stall
Axle/Gears: Moser 9" w/ disc brakes, 4.11, QA1
Hey guys, I have a similar question about what oil pans fit in a stock front end '82 Z28. I'm now building a 383 and will be using new Hedman long tube headers. I have a stock pan and a 7qt kicked out pan. (10.5" wide) Will the kicked out pan fit with the long headers and a stock size starter?
Of course after reading 86LG4's post I probably can use the stock pan if the kicked out doesn't fit. Probably going to make about 450/475 HP. Occasional brief heavy breaking, when dumping the guy in the other lane. I don't know if the stock pan has a rear baffle though.
Any thoughts?
Old Mar 14, 2016 | 03:56 PM
Car: 1988 Camaro
I run hedman long tubes on mine with the summit 7 qt kicked out sump pan. Stock starter will fit as well but I'm running a high torque gear reduction mini starter to save weight and crank over a 10.5:1 compression engine easier
Old Mar 14, 2016 | 04:19 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Will a stock oil pan even work on a stroked engine?
Old Mar 14, 2016 | 05:33 PM
86LG4Bird's Avatar
Yes. Depending on what kind of rods, you may have to "massage" the pan a bit near the rails.
Old Mar 14, 2016 | 06:09 PM
Andy-Z28's Avatar
Car: 1982 Z28 #7X25
Thanks Knight Rider, hopefully I won't need an expensive mini starter. I should be at 10.0 compression with 64cc heads.
When I have more questions on this upgrade I'll look for y'all.
Old Mar 14, 2016 | 11:18 PM
Car: 1988 Camaro
No prob man. Your welcome. It really is worth the money to setup a good oil control system. I have seen 20-35 HP gains from good pans, windage screens, etc.
I like to tell people in a simple term... Try to run in the swimming pool or lake. It's really hard to do. The crank has to do that in some degree on stock systems. By getting the oil away from crank and keeping the splash oiling off the crank, the crank now has nothing it has to "run" through as it turns.
91banditt2
Mar 17, 2020 06:52 PM
mrestrictrplate
Mar 8, 2016 11:53 AM
Tuned Performance
Mar 7, 2016 11:44 AM
tcrisp
Mar 6, 2016 05:00 PM
JoeMama54
Mar 3, 2016 08:21 PM
