Why does my car crank for so long before starting?
Old Mar 19, 2016 | 10:51 AM
Mattkovitch's Avatar
Car: Firebird
Engine: 305 tbi
My car is a 91 with a 305 and a throttle body and I'm wondering why it cranks for much longer than normal when I start, but only from cold starts. If its already warm then it starts right up. What's the problem? Or is it just an older car thing?
Old Mar 19, 2016 | 11:20 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Why does my car crank for so long before starting?
sounds like it might be your temp sensor. The one on the intake, not the one in the driver's side head.
How much longer crank time are you talking? Here is a resistance chart at different temperatures. Use a multimeter and check the resistance cold.
https://www.thirdgen.org/forums/atta...ase-ctsmat.gif
Old Mar 19, 2016 | 11:30 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I've been battling this issue forever on my TPI. Replaced all ignition and fuel components with no change. Will test the temp sensors...
Old Mar 19, 2016 | 11:44 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Have you done a leak down test to check for pressure leaks?
Old Mar 19, 2016 | 12:04 PM
thtanner's Avatar
Yep. Everything is 100% perfect. All parts are brand new end to end, and everything tests within spec. Zero vacuum leaks, etc. Even have a new MAF.
Not meaning to detract from OPs post. His is a TBI so could be totally unrelated.
Old Mar 19, 2016 | 12:14 PM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
Check your values with a scanner with cold engine. I also had cold start issues last spring, turned out my 5V circuit in the ECU was the problem. It gave less than 5 Volts, so for example the temp sensor reported +30 degrees C, when it was +6 degrees. Also the TPS reported 20% throttle at WOT. Replaced the ECU, and it was good again.
Old Mar 19, 2016 | 01:20 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Check your fuel pump relay, may be waiting for oil pressure to build up before the fuel pump kicks on.
Old Mar 21, 2016 | 08:32 AM
Car: Firebird
Engine: 305 tbi
its weird has done it since i bought it. The other thing is that sometimes when it is warm it starts up and revs up to about 1200-1300 then drops down and dies, unless i quickly put it in gear before it dies.
Old Mar 21, 2016 | 07:13 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
Same exact isue in my tpi as well, only from cold start. Let me know what u find
Old Mar 21, 2016 | 07:14 PM
thtanner's Avatar
ECU and CTS are on my list currently. Will advise as soon as I have the car back (2-3 weeks). She's in in the paint shop!
araugh
Jul 8, 2022 09:50 PM
Ricky16
Nov 2, 2019 10:10 PM
'91CamaroRS
Mar 16, 2016 09:07 AM
marz1129
Mar 10, 2016 04:34 PM
CTiROC
Mar 9, 2016 06:22 AM
