Unknown plug
Old Apr 13, 2016 | 03:59 PM
Shortstrokin's Avatar
Unknown plug
I'm working on my 87 z28 I recently picked up. In the process of trying to hunt down the wiring for the temp gauge I came across another plug but I can't figure out where it goes. I remember seeing it on my other third gen but can't place it.
It comes from around the distributor and oil pressure sensor area.
Cam anyone help?
Old Apr 13, 2016 | 04:09 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
That is the plug for the oil pressure switch that runs the fuel pump . The orange and tan with white tracer wires are the giveaway on that .
Where there are only two wires on it , you must have had two units screwed into the block monitoring the engine's oil pressure , that one with it's two wires for the fuel pump and a different one with one wire for the oil pressure gauge on the dashboard .
That switch , BTW works in parallel with the fuel pump relay in that either/or will supply power to the fuel pump under the right conditions (when there is oil pressure and/or when the ECM tells the fuel pump relay to actuate .....
Old Apr 13, 2016 | 04:49 PM
Re: Unknown plug
The car has been converted carb so I shouldn't need it but at least I know what it is now. Thank you very much.
Back to my hunt for the engine temp sender wiring....
Old Apr 13, 2016 | 05:27 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
If you are running a mechanical fuel pump with your carb setup and are not using the in tank electric pump you are right , you don't need those wires . Is the electric pump still in place and your using the mechanical pump to draw through it ? I would think in that situation it would flow fuel better if the original pump was removed ? But if you have no fuel delivery problems I guess I'd leave it till some other time ya end up having to work on the fuel tank , like if the gauge sender dies .
Oh , and , if your looking for the wire under the hood that controls the coolant temperature gauge , it'll be a solid green wire that's thinner (smaller gauge wire) than the ones for your fuel pump are .
Old Apr 16, 2016 | 01:56 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Unknown plug
and this is why alot of 3rd gen camaros end up as parts , some "person" not taking the time to put things "right " rather than "cobbled"
Old Apr 16, 2016 | 08:44 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
all set ...
Old Apr 16, 2016 | 09:16 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
All set
Old Apr 16, 2016 | 09:36 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
All set
Old Apr 16, 2016 | 10:40 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Unknown plug
I enjoyed reading your posts OrangeBird. I remember when I first joined TGO and if I would have received an answer like vango posted probably would not be on here today.
Old Apr 16, 2016 | 11:11 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Unknown plug
Hi Edward ,
Rusty and I talked and he told me he meant no meanness , it's understandable that sometimes things don't look the same in print as they do if we were just hanging out talking cars , so I'm all for giving the guy the benefit of the doubt and Rusty has MY apologies for jumping on him before speaking with him first .
jharrison5
Jun 11, 2016 10:11 AM
truckerz
Apr 14, 2016 02:59 PM
AaronS
Apr 8, 2016 03:32 PM
B4C5.7
Apr 8, 2016 05:40 AM
firechickenmike
Interior Parts Wanted
Apr 7, 2016 07:52 PM
