What is this sensor?
Old May 13, 2016 | 04:52 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi guys, I' ve already posted this in the Euro section, maybe here I' ve more chance to solve this: I need to know what is the purpose of the sensor in the red circle.
Siince I' ve a stalling probelm when hot, I' m wondering if is this the reason of this problem.
The engine is a 3.1 V6 LH0.
Thanks guys
Attached Thumbnails What is this sensor?-13055434_10206044402695657_1723814251385609126_n.jpg
Old May 13, 2016 | 05:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: What is this sensor?
Looks to be in the water port so I'm guessing its the fan switch.
Old May 13, 2016 | 08:02 AM
Engine: 3.1 LH0
Thank you TTOP, it' s a starting point. The problem is no wire is connected to it, since the fan was manually activated from a VW(!) relay. But the fan starts with the coolant sensor, am I right? Now, I want to restore the original system, but I have no idea where to start in order ro rewire the fan switch. Can cause this the car to stall due to overheating?
Old May 13, 2016 | 10:41 AM
Camatruder's Avatar
Car: 88 Camaro V6
The sensor is the water temperature sensor for the computer. There's another sensor at the front left corner of the valve cover for the gauge.
Old May 13, 2016 | 12:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks guys
See your other thread for the hot stalling issue fix.
As for the switch circled in red, it is the cold start injector switch. It is not used on the 3.1l engines. The previous 2.8l engines used the cold start switch. Maybe the intake manifold is from a 2.8l engine?
The sensor to the left of it is the CTS for the ECM.
RBob.
Old May 14, 2016 | 05:10 AM
Engine: 3.1 LH0
I don't know the car's history, I think somethings were changed in time... Can this 2.8 manifold damage the engine somehow?
Old May 14, 2016 | 09:22 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Shouldn't be an issue if it is the 2.8 intake. The engines are exactly the same except the 3.1 has a longer stroke than the 2.8. That and the 2.8 is mass air flow and the 3.1 is manifold air pressure, 2.8 uses 1227165 ecm and 3.1 uses 1227730. But no major mechanical differences otherwise. They're both Gen I 60 degree V6 engines.
My car used to be a V6 but I don't remember anything like that in mine, but I'm not sure. I have digital service manuals for 88-90, but 90-92 is basically the same. Since you have the LHO 3.1 your car should be 90-92.
Heres what I found in 1990 Service manual.
Old May 19, 2016 | 11:37 AM
Engine: 3.1 LH0
Wow, thank you Fire! Crystal clear!
Camaro510
Northern California
Jun 25, 2016 06:25 AM
IROCThe5.7L
Oct 29, 2001 01:21 PM
FiReBReTHa
Oct 10, 2001 09:52 AM
camaro 22
Apr 23, 2001 07:24 AM
JRoy91RS
Sep 28, 2000 04:38 PM
