Fuel Pressure Regulator
Old Jun 2, 2016 | 01:18 AM
sabre08's Avatar
Car: 91 Firebird
Engine: 3.1L 6cyl
Can you replace the fuel pressure regulator on a 1991 Pontiac Firebird 3.1 base model without having to replace the entire fuel rail?
Old Jun 2, 2016 | 03:19 AM
sabre08's Avatar
Car: 91 Firebird
Engine: 3.1L 6cyl
Re: Fuel Pressure Regulator
Never mind, I have read on a bunch of sites and in the Haynes and Chilton's manuals that you cant. Looks like Im hitting up Pic-a-part and praying they have one that works better than mine.
Old Jun 2, 2016 | 10:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, you can replace the FPR without replacing the entire rail.
RBob.
Old Jun 2, 2016 | 01:13 PM
sabre08's Avatar
Car: 91 Firebird
Engine: 3.1L 6cyl
Really? Great! How would I go about doing that. Everything I have read says that you have to replace the entire rail because it is all one piece.
Old Jun 2, 2016 | 08:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It has been a while, but basically, need to remove the plenum. I leave the cables attached to the TB and rotate the whole works forward.
The FPR has the 'safety screws' (Torx) to attach it. Can either purchase a safety bit, or drill a hole in a regular bit, or knock off the little 'stubs' with a hammer and punch.
Remove the FPR screws a little at a time. It may spew some fuel out if there is pressure.
Remove the FPR can, diaphragm and spring. Install new spring and diaphragm, install screws.
RBob.
Old Jun 3, 2016 | 01:40 AM
sabre08's Avatar
Car: 91 Firebird
Engine: 3.1L 6cyl
RBob.
Thanx I will give that a try.
91banditt2
Aug 11, 2021 10:54 AM
1Aauto
Sponsored Vendors
Nov 16, 2016 09:45 AM
racerx520
Apr 17, 2016 07:14 PM
Scorched1984
Apr 13, 2016 06:07 PM
instaldave
Apr 7, 2016 06:14 AM
