a/c connector thread question
Old Jul 4, 2016 | 09:21 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
I wanted to change to the R134a and my cardealer ordered some new connectors to be able to fill the lines. the connector on the "high"-side fitted well over the existing thread but the other on the "low"-side, we got a false size. Can anybody tell me what size this thread is? is it a regular 1/8"?
Or should I take out the existing connection-piece and find a part which fits dirctly on the bung in the line?
existing connector
new fast connector with valve
Old Jul 4, 2016 | 09:59 AM
Re: a/c connector thread question
That looks like the high side valve.
The low side one is on the accumulator/dryer.
You don't really "need" a valve on the high side for anything, except hooking gauges up to it. It's not really worth creating an extra potential leak point there, just for that. I'd suggest putting the original cap back on it after installing a new O-ring in the cap, and leaving it alone.
Old Jul 6, 2016 | 07:39 AM
Car: '91 Z28
Engine: LB9
Found this picture:
I ordered a set of fittings with hopefully the right size now...
In the garage they told me that on one side they are filling the R134a and on the other one some lubricant. That's why I need adapters on both sides.
Old Jul 6, 2016 | 01:44 PM
That's not how it works.
You just pour the oil into the suction port of the compressor and the accumulator/dryer; about half into each. Then you put the refrigerant in at the low side port.
The high side adapter is unnecessary for anything other than hooking up a gauge to see what the pressure is there. Not entirely useless, but by no means necessary. In fact some AC systems don't even have a high side port because what little utility it provides is outweighed by the leaks it usually causes.
Old Jul 6, 2016 | 04:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Some shops will initially charge an evacuated system through the high side with the refrigerant container upside down (liquid), followed with topping off on the low side as vapor. I think they do this to minimize dry start compressor time. There are other considerations, risks and debate with doing it this way.
I just charge from the low side as vapor; less worries.
Old Jul 7, 2016 | 02:22 AM
Car: '91 Z28
Engine: LB9
Gentlemen, thanks for clarifying!
Old Jul 7, 2016 | 10:14 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Your AC will work BEST w/ R12. If I knew your location, I'd post a nearby Ebay or Craigslist add, for R12. Find a shop who can charge it w/ R12. IMO, based on experience.
Old Jul 15, 2016 | 04:26 AM
Car: '91 Z28
Engine: LB9
If you know a Location in Switzerland that would be helpful
Old Jul 15, 2016 | 09:08 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Can't help you there!
Old Jul 15, 2016 | 09:34 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Not to hijack this thread but have to speak on MY personal experience...
Mike...I agree with you on the R-12...the stuff is good, and I had it for years since my first new 78 K-5 Blazer.
BUT.....I just retro'd 2 of my cars within the last 3 weeks. I replaced the Dryer, orifice tube(standard white), hose assembly's, and NEW AC-Delco compressors.
I flushed, Nitrogen air dryed condensor and hard lines and pulled a vacuum to 28.75 HG's. Held for 2 days. Charged with 2.80lbs, along with the 6-8oz of PAG Oil.
The day I did it, it was 95* and 65% humidity in Alabama and I was getting 38* degree air out the center vents. (with a calibrated thermometers)
Granted, our cars were set up for R-12 for the best performance, but its getting harder and harder for SOME people to acquire R-12. I could have gone that route, but choose not to.
So on that note.......Not R-12......but R-134A.
If done correctly, you can be sucessful.
Back to topic
Old Jul 18, 2016 | 03:52 AM
Car: '91 Z28
Engine: LB9
Thanks all for the feedback.
A friend did the retrofitting on his '90 GrandPrix and is quite pleased with the result.
I'll let you know if it worked on mine too.
BrianI
Jul 15, 2016 07:09 AM
84-z28-
Jul 8, 2016 12:59 PM
I_R_O_C_Z_2_8
Jul 3, 2016 04:35 PM
stahrman0612
Jun 20, 2016 02:22 AM
jackhammer
Jun 6, 2016 05:47 PM
