92 camaro rs start
Old Jul 28, 2016 | 12:10 AM
Anthony0128's Avatar
92 camaro rs start
've recently started fixing up a 92 camaro rs 5.0 305 tbi that was passed down to me. It had been sitting for 8 years and I threw in a new battery and cranked it. It turned on but did not stay on since the gas was bad. I started putting in some work to hopefully getting it running again and wanted to know if I'm missing anything
-dropped tank replaced tank and fuel pump
-cleaned fuel lines and replaced fuel filter
-cleaned out radiator and hoses
-drained old oil replaced it with new oil
-replaced thermostat and water pump
-took out tbi cleaned it and put new gaskets
Is there anything I'm missing before I try to get it running again ?
Old Jul 28, 2016 | 01:32 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: 92 camaro rs start
The fuel pressure regulator could very well be bad after sitting that long, do a fuel pressure check to see if its bad.
Old Jul 28, 2016 | 03:23 AM
Alright thanks, is there anything else I should check for ?
Old Jul 30, 2016 | 06:18 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
You should think about replacing all rubber coolant hoses, that rubber gets hard after that long, last thing you want is for it to blow out while you're driving it down the road. Shouldn't be a problem while you're just trying to get it started, but I'd definitely do it soon.
Old Jul 30, 2016 | 11:18 AM
I actually just purchased those yesterday thank your for the reply though ! Would there be anything else I need to do to hopefully get it running ?
Old Jul 30, 2016 | 11:39 AM
fervernt's Avatar
Other than a basic tune-up once you have it up and running(plugs, wires if needed, and cap and rotor), I think you should be good. Have you checked your accessory belt? Same deal as the hoses, they get brittle sitting that long. If it's not cracked I wouldn't worry too much about replacing it, but I believe they make some kind of belt conditioner or something, maybe look into getting that. Also may want to look at the trans fluid, if it looks clean I wouldn't worry, but if its dirty you may want a flush depending on your mileage. do research on that one, I've never personally had problems flushing a trans, but I've heard some horror stories about getting a flush on a high mileage transmission and it wont even go into gear afterwards. Looks like your in pretty good shape though! Good luck with it man.
Old Jul 30, 2016 | 11:48 AM
fervernt's Avatar
P.s. everyone likes pictures man, let's see what you're working on!
Old Jul 30, 2016 | 12:10 PM
Thanks for the help man ! And yeah of course she's not pretty yet but she'll get there!
Old Jul 30, 2016 | 12:34 PM
fervernt's Avatar
Aw that's not bad, body looks straight, get some paint on her and good to go! All these cars lose their clear coat, gm really skimped on the quality paint with these.
Old Jul 30, 2016 | 12:35 PM
Yeah it's peeling rather bad and has a few dents and bit of rust around the trim of the windshield but I'm planning on fixing it up
BG1959
Jul 20, 2016 02:22 PM
mikeyt
Mar 21, 2016 06:53 PM
Pat
Aftermarket Product Review
Apr 2, 2001 07:35 PM
david auster
Mar 8, 2001 09:37 AM
rdayz28
Feb 27, 2001 03:19 PM
