Dipstick jumping open under load.
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
My dipstick pops up three inches, when I put the hammer down, no problem otherwise. Is this normal? Should there be an o-ring or some other fastener to lock down the dipstick? Engine is small block with dipstick on driver's side, 350 bored out to 355. Engine recently rebuilt, 700 miles on it. Oil pressure = 60 psi, till engine warms up; oil pump is new, same mileage. Tiny question, I know, but there it is. Saw the other posts on the subject, but puzzled.
Re: Dipstick jumping open under load.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Yep, you are building some pressure in there.
Does it pop at all under normal driving conditions?
It's okay, unless I put the pedal to the floor.
Yup, classic blowby...
There's 3 main places that can occur:
Of course there's the oddballs; holes in pistons, cracked castings, and so forth. Let's leave those aside for the time being.
- Rings. Need I say more.
- Exhaust valve guides.
- Intake gaskets.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
No, not necessarily: in most stock heads, there's an exhaust passage that passes through the intake gasket. If that part of the gasket fails, exhaust goes right into the crankcase.
oh yep....didnt think about that effect from crossovers and heat riser passages. Luckily all that crap is in my past!
A small o-ring on the top of the dipstick was missing. Bought a new dipstick; no problem now.
propaintball96
Apr 12, 2016 01:30 PM
