Seized engine??
Old Sep 22, 2016 | 11:00 PM
Sutliff01's Avatar
Car: 1986 Trans Am
Seized engine??
What are the probabilities that my engine is seized after siting outside in Indiana weather for almost 20 years
Old Sep 23, 2016 | 09:01 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Re: Seized engine??
Sitting outside how? In a car? Or on the ground? Were all the holes plugged up? Air filter on it, etc.? The only way to know for sure is to try turning it over. You could pull the spark plugs and use a wrench on the front to try to turn the crank. Or if its still in the car put a new battery in it and give it a go
Old Sep 23, 2016 | 12:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Seized engine??
If it's seized up after sitting around that long then it needs a bit or repair. Providing it's not full of water, chances are the rings are just stuck to the cylinder walls. Even if that's all that's wrong with it, the rings won't be in any kind of good condition and a rebuild should be done. It may start and run but probably won't run very well.
Old Sep 23, 2016 | 03:59 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Seized engine??
Yes , no , or maybe ... In no particular order ...
Old Sep 23, 2016 | 04:39 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Seized engine??
I'd say the odds are better that is is seized than not.
Old Sep 26, 2016 | 10:53 PM
Sutliff01's Avatar
Car: 1986 Trans Am
Re: Seized engine??
It's been in the car
Old Sep 27, 2016 | 01:37 PM
Toqwik's Avatar
Re: Seized engine??
I was doing a mopar engine swap once and the engine was in my garage for 3 weeks and it seized. Pull the plugs and fill with marvels mystery oil and let it sit. The longer the better. Break the motor loose with a breaker bar till it spins free. Then crank a few times with the starter. I put that stuff in a motor that sat in my grandfathers field for 20 years uncovered and it broke it loose. You don't have anything to lose at this point. Give it a try.
ppborceb
Oct 25, 2016 03:56 PM
xbazzarex
Oct 1, 2016 01:02 PM
rocn7roc
Sep 24, 2016 09:21 AM
Harleystrada
Sep 22, 2016 08:15 PM
Ming
Sep 21, 2016 12:43 PM
