Service Engine Soon
Old Sep 19, 2016 | 05:01 PM
ppborceb's Avatar
Car: Pontiac Firebird
Engine: 2.8L V6
Transmission: Automatic with OD
Axle/Gears: Don't know
Service Engine Soon
I replaced the O2 sensor, but the service engine soon light didn't go off.
I would appreciate it very much if someone would tell me how to cancel the light.
Thanks,
PPB
20160919.1.180100
Old Sep 20, 2016 | 02:28 PM
Knucklehead39's Avatar
Car: 70 SS350, 89 IROC-Z, 95 Z-28
Engine: 350, 305, 350
Transmission: 4-spd, 5-spd, 6-spd
Axle/Gears: 3.08, 3.08, 3.31
Re: Service Engine Soon
Disconnect the negative terminal of the battery for 10 seconds. You will have to reset your radio presets.
Old Sep 20, 2016 | 05:40 PM
ppborceb's Avatar
Engine: 2.8L V6
Hi Knucklehead39,
Thanks for the suggestion...
I did it, but it didn't work... the light is still on just as bright as ever.
I could use some more suggestions from you guys/gals.
PPB
20160920.2.184000
Old Sep 20, 2016 | 06:25 PM
I should have said leave the battery disconnected for 30 seconds, not 10. If you left it off for at least that long, it sounds like either there's something else wrong or the connection is bad. Make sure the plug is solidly connected. Why did you replace the oxygen sensor? Did you get a code 13 from the computer, or were there other symptoms?
Old Sep 20, 2016 | 11:52 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Could always cancel the light by simply removing the bulb...
But the best option is to get your Light Flash Code and continue to diagnose the problem until it is resolved..
Old Sep 21, 2016 | 06:46 AM
As the above says, you need to find out what's wrong. There are plenty of discussions on line of what to do when the check engine light comes on. Though written for W-bodies, here's a good one:
http://www.seanster.com/scantool/ecm-codes.html
Old Sep 22, 2016 | 09:10 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
I would try and pull out your ECM and verify that your PROM chip is fully seated. When I bought my current Camaro, the SES wouldn't go out and the flash codes wouldn't work. I pulled ECM and realized the PROM wasn't fully seated. I pushed it in and the light went out and the flash codes worked.
Old Sep 23, 2016 | 11:25 AM
ppborceb's Avatar
Engine: 2.8L V6
Hey Knuckle,
I did 10 seconds just as you suggested, but now I'll try 30.
I don't know what you mean by 'make sure the plug is solidly connected', and I didn't get a code 13 from the computer because I didn't connect anything anywhere, and furthermore I wouldn't know what to connect where.
Do I sound like a 'newbie' that doesn't know what I'm doing... because I am!
I replaced the O2 sensor because everyone said that 90% of the time that is the problem so I just went ahead and replaced the sensor.
Hey Camaro,
Or, I could put a piece of black tape like 'Click and Clack' use to recommend!
Thanks guys,
PPB
20160923.5.122400
Old Sep 23, 2016 | 11:54 AM
Don't apologize for being a newby -- everybody was one once. When I said make sure it was plugged in, I was talking about making sure the new oxygen sensor was securely plugged into the wiring harness. If disconnecting the battery >30 seconds doesn't shut off the light, then the O2 sensor wasn't the problem. In post #6 above I suggested you follow the instructions in a web site to obtain real data on what's wrong. You need nothing more than a bent paper clip to run the test. Connect it to the top right two contacts in your computer link (under dash to right of steering column) and follow the directions. Let us know what the light blinks.
Old Sep 26, 2016 | 10:19 AM
ppborceb's Avatar
Engine: 2.8L V6
Hi guys,
I'm finally back after reading, re-reading, and re-re-reading the link in #6 and following Knuckle's instructions for the paper clip insertion and BINGO
I get 12,12,12,34,34,34,12,12,12!
Now all I have to do is make sense regarding the MAP explanation.
Also, I removed the ECM fuse, waited a few minutes, put it back in, restarted the car, but the light came back on and stayed on!!!
Now WHAT?
I need more help guys.
PPB
20160926.1.112900
Last edited by ppborceb; Sep 26, 2016 at 10:29 AM. Reason: Trying to reply,but I get a message that I logged on....
Old Sep 26, 2016 | 02:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Originally Posted by ppborceb
Hi guys,
Now WHAT?
PPB
20160926.1.112900
The ECM is expecting input from the MAP sensor and it's not getting it. So the ECM turns on the check engine light.
Locate the MAP sensor (I can't help you other than it's under the hood) and make sure the vacuum line and electrical connector are hooked up to the sensor.
The map sensor looks like this (click on the little images):
http://www.rockauto.com/en/catalog/p...le.com+URL+%2F
Old Sep 26, 2016 | 02:38 PM
ppborceb's Avatar
Engine: 2.8L V6
Hi Paulo,
Thanks for the information.
Now, I'll go out to the garage and try to find the little 'bugger', but as you can see from the prior postings, it's going to take a while because of my inexperience.
PPB
20160926.1.153800
Old Sep 26, 2016 | 03:23 PM
Google is your friend. Just Google:
map sensor location gm 2.8 v6
If that's the wrong engine, change the ID.
Old Sep 26, 2016 | 04:23 PM
ppborceb's Avatar
Engine: 2.8L V6
Hi GPen,
I don't know where the ECM & prom chip are located AND I don't know what they look like either... any guidance would help at this point.
PPB
20160926.1.172200
Old Sep 28, 2016 | 04:58 PM
See Paulo post above. Code 34 means a bad/disconnected MAP sensor. I would order a new MAP sensor for your car, look at the link I posted to find your MAP sensor, and replace it.
Old Sep 29, 2016 | 03:22 PM
ppborceb's Avatar
Engine: 2.8L V6
Hi Knuckle&Company,
Well, I'm finally back after looking for that MAP/MAF under the hood, but now I'm confused about what I am supposed to call that little 'bugger'.
I was reading the Haynes manual and I'm seeing two explanations for code #34.
One says after 1989, it's called a MAP and the other says 1989 and earlier it's called a MAF. So, my question is are they really the same, but only called differently?
Also, I'm still not sure that I'm looking in the right place, and I'm sure that someone will steer me in the right direction and then I'll go and get MAF/MAP.
PPB
20160929.4.162100
Old Sep 29, 2016 | 03:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi Knuckle&Company,
PPB
20160929.4.162100
Before and including 1989 , the engine was a 2.8 and used a MAF (mass airflow sensor) mounted in among all the factory plastic/rubber intake piping that runs from the factory air cleaner to the throttle body . Is the entire factory air inlet system from air filter to throttle body still in place ? And hopefully not removed for some dinky little useless "cone of death" K&N filter slapped onto the end of the throttle body ? If so , you will find your MAF is , after a 90ish degree bend , the big plastic pipe leading away from the air cleaner and headed to the square plastic box just behind the top of the radiator . It will have a wire harness going to it with 3 wires in it . There is unfortunately no "field test" for the MAF , as long as two of the 3 wires are +12V and ground , with the third being a 5 volt data line from the ecm , then yea your MAF is likely toast . Do NOT buy a $99 autoparts "special" rebuilt MAF or you'll be sorry , do a bit of research on what's known good these days (It used to be Bosch , but i'm not so sure anymore) and buy good and buy once .
PS , I'm pretty sure that in 1990 , when the 2.8 became a 3.1 is when it went from MAF to MAP , just to let you know why the same code could come to mean two different parts ......
Old Oct 5, 2016 | 09:09 AM
ppborceb's Avatar
Engine: 2.8L V6
Hi All You Helper Guys,
I'm finally back after reading, searching, and watching YouTube videos regarding cleaning, testing, replacing, and many 'how-to' videos about MAF sensors.
After seeing how expensive new MAF sensors were going to be, I tried to clean the MAF with CRC mass air flow sensor cleaner; But, first what a job to get it out!
And of course, it didn't work... still got code #34.
Now I'm trying to figure out what this 'ecm' thing-a-ma-gig is and what to do with it.
And of course, I have to find out where it is and how to get at it.
Help guys!
PPB
20161005.3.100700
Old Oct 25, 2016 | 01:14 PM
ppborceb's Avatar
Engine: 2.8L V6
Hello Again!
Well, I'm back and the light is OUT after following your recommendations of BUYING A NEW (NOT A REMANUFACTURED) MAF SENSOR.
So, I want to thank Knucklehead39, Camaro86IrocZ, G.Penrod, paulo57509, OrangeBird.
All of your suggestions were very helpful to me and I hope that in the future, I might be able to help a newbie like me.
Again, thanks guys.
PPB
20161025.2.141100
Old Oct 25, 2016 | 03:56 PM
Glad to hear it worked. We're all newbies at some time or other (some for longer than others . . . . . . ).
Bobby_80s
May 6, 2007 07:53 PM
I H8 WWD
Apr 28, 2007 10:45 AM
darcops
Apr 24, 2004 11:43 PM
Steve
Aug 13, 2002 11:40 AM
sancho
Jul 19, 2002 11:14 AM
