Fuel Tank Issues
Old Jan 19, 2017 | 07:36 PM
racerx520's Avatar
Fuel Tank Issues
hey guys, wasn't sure where else to post this. I recently changed out my fuel pump twice (the pulsator went the 2nd time and i figured just change out completely). Since then, I have been getting a STRONG odor of fuel whenever i fill the tank to full, or nearly full. Once it dips down lower, its fine. I looked at the fuel neck and saw the filler-flap doesnt close all the way. I'm thinking this may be the issue, since sometimes at certain gas pumps i have to hold the fume-return open on the pump, otherwise it doesnt seem to vent properly.
I suppose my question is, do you guys have any suggestions on how to fix this? with my new Racetronix pump, if i run the car lower than 1/4 tank, the pump will overheat and shut down. Has anyone had any similar issues? I had this tank repaired once already because the filler neck had a crack (apparently a common issue in these cars from the factory). Thanks guys, i appreciate any help....and so does my house and family lol
Old Jan 19, 2017 | 08:10 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Fuel Tank Issues
could be 2 things,
1. you might not have got the tank to seal properly around the locking ring (unlikely as your smell goes away)
2. blocked tank vent, pretty common issue, apparently you cant buy them anymore though. (much more likely)
Isnt there a stick somewhere about how to repair/clean one on here somewhere?
Old Jan 20, 2017 | 06:00 AM
racerx520's Avatar
Originally Posted by zed-028
could be 2 things,
I will try find the sticky, thank you very much
Old Jan 20, 2017 | 09:01 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Start at post #15
https://www.thirdgen.org/forums/hist...ent-valve.html
Old Jan 20, 2017 | 11:56 AM
racerx520's Avatar
Originally Posted by Bob88GTA
Thank you, i saw this while i was doing my searches. Wasnt sure if this could be the culprit....will have to get this out and get to work. I am just hoping i didnt damage the fuel filler neck when i did the pump last. I have had it repaired once already.
Old Jan 21, 2017 | 11:25 AM
BrianI's Avatar
Put a 4th gen plastic tank in it. Has a detachable filler neck. I'm doing an LS swap and I'm using one. You would need to adapt the fuel lines but it's a much better sending unit /pump set up than the 3rd gen.
Old Jan 21, 2017 | 11:48 AM
racerx520's Avatar
wish i had known about this before. I have already replaced the pump and sending unit. I am going to try to do the vent valve when i get a chance. Right now, i duct taped the fuel cap to the neck to prevent any odor from escaping through the cap.....the house stopped smelling like fuel almost immediately after. I am beginning to think the problem is right up in the fuel cap/filler area.
Old May 9, 2022 | 09:14 AM
Eightyninef's Avatar
The original tanks had little of a cup. The replacement tanks had a deeper cup.
Also, get the 1LE fuel sock. It's double ended.
