NEED HELP!! 25th Anniversary
Old Feb 1, 2017 | 04:50 PM
91camaro25th's Avatar
Ive been racking my brain.
92' 25th 305 TBI
When cold car stumbles, surges and only stays running as long as im playing with the throttle. When it warms up, it will Idle fine all day long, but when its put into drive, it stumbles and has no power.
Replaced:
EGR
TPS
IAC
ICM
fuel pressure regulator and all gaskets/seals in throttle body
MAP
cap/rotor
Any help would be appreciated.
Old Feb 1, 2017 | 05:21 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: NEED HELP!! 25th Anniversary
check your fuel pressure might be the fuel pump or filter
Old Feb 1, 2017 | 05:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Or your cts or iat could be bad.
Old Feb 1, 2017 | 06:16 PM
I forgot to mention thathe I already replaced the fuel filter as well.
Cts?
Old Feb 1, 2017 | 09:46 PM
Engine: Lb9
Transmission: M20
Originally Posted by 91camaro25th
Cts?
Coolant temp sensor
Old Feb 2, 2017 | 07:58 AM
gotcha! lol
Would the coolant temp sensor really cause my issues?
Old Feb 5, 2017 | 02:52 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Coil?
