up side down pistons..
Old Mar 7, 2017 | 09:25 PM
blaze15301's Avatar
So i bought a motor off a friend of mine. it was in his pulling truck. i decided to pull the heads. Found out the pistons are up side down.
if i go to 64cc heads will i have issues with the valves?
Can i either just spin the rod 180 or do i need to just spin the piston? here are the specs.
miles less then 2k
58 cc heads shaved 020
forged 2 valves relief pistons
eagle rotating assembly.
Old Mar 7, 2017 | 09:36 PM
Re: up side down pistons..
Post a photo.
Old Mar 7, 2017 | 09:50 PM
blaze15301's Avatar
blaze15301's Avatar
the marks are very slight. thats why im thinking i will be ok going to a bigger cc head
Old Mar 7, 2017 | 10:01 PM
From what that photo shows, it's about impossible to tell.
Got one that shows one whole bank?
Old Mar 7, 2017 | 10:15 PM
blaze15301's Avatar
Ill post one tomorrow.
Old Mar 8, 2017 | 12:51 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I believe the valve reliefs should face the lifter valley/intake manifold.
Old Mar 8, 2017 | 03:23 AM
Twin_Turbo's Avatar
Swap them around.
Old Mar 8, 2017 | 06:59 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It kind of looks like the valves have kissed the pistons a bit to me.
Anyone else see those marks in the pistons where the valve reliefs should be??
Old Mar 8, 2017 | 07:42 AM
Twin_Turbo's Avatar
Yes they did kiss.
Old Mar 8, 2017 | 08:10 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pull them out and swap them around.
Old Mar 15, 2017 | 06:32 AM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
you have it apart it would be foolish not to fix it NOW
Old Mar 16, 2017 | 06:43 PM
NoEmissions84TA's Avatar
You can't just flip the rods, unless they were installed backwards,
which is why the pistons are upside-down. This would be your
luckiest option. Fix it right - now.
If you are using a hydraulic flat-tappet camshaft, very carefully inspect
the lobes and lifter bases. It might already be too late.
You are lucky that any valve locks did not come loose and a cylinder
did not suck a valve into the engine.
You will also have to inspect the crank fillets and rod bearings.
The bigger chamfer in the big end of the connecting rod goes
toward those fillets (or, smaller chamfers go together at the center
of the rod journals).
Old Mar 29, 2017 | 10:08 PM
blaze15301's Avatar
thanks guys i flipped everything around im in the process of putting it back together.
Old Mar 30, 2017 | 01:52 AM
So the pistons were installed correctly to the rods???
And yes, they were absolutely upside down.
