TPI no power and stalling (need help from the guru's)
Old Mar 24, 2017 | 08:04 AM
Pat1990GTA's Avatar
Car: 1990 Trans Am GTA
Engine: 383 HSR Profiler heads
Ok guys i need some help
​​​​​​I have a 89 Camao 305 tpi and I'm pretty frustrated with it
It has this on going issue with stalling when going into drive or reverse and having no power
​​​Previous owner has tried new injectors, Mass air flow, distributor, spark plugs/ wires, o2 sensor, fuel filter, torque converter, iac and he even had the motor rebuilt thinking it was a mechanical thing
The car has great fuel pressure and seems to run good other than have no power and stalling
the car wont stall if you crank then idle up or feather the gas into gear it wont stall
The timing and idle has been set properly (many of times)
The iac counts jump pretty high in park or reverse like it has a heavy load
any ideas? Coud this be a tranny issue some how?
Any help would be much appreciated!
Old Mar 24, 2017 | 09:14 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: TPI no power and stalling (need help from the guru's)
Have you checked out the TPS?
Old Mar 24, 2017 | 09:21 AM
Pat1990GTA's Avatar
Whats the best way to check it?
​​​​​​​ive set it a .53 with the throttle closed
Old Mar 24, 2017 | 10:59 AM
fervernt's Avatar
I don't remember what the best way to check it was or what the numbers are supposed to show. Do a search, there's plenty of write-ups on it. Other thing I'd check is your EGR valve, just cap of the vacuum lines to and from it and see how it runs after that. It can affect you're idle pretty significantly if it's bad.
Old Mar 24, 2017 | 11:11 AM
Pat1990GTA's Avatar
Ok i will check it out again
And i already plugged off the egr (which is also new) with no difference
Old Mar 24, 2017 | 11:22 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
.54 is the tps spec, have you ohmed the injectors and checked fuel pressure ?
Check engine light on ?
Old Mar 24, 2017 | 05:21 PM
Pat1990GTA's Avatar
O sorry its at .54v
The injectors are new 19lb bosch and the fuel pressure is 45 to 48 psi
No check engine light
The iac count goes from 25 to 35 in park to 150 to 160 in gear
Old Mar 25, 2017 | 09:00 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
This is key to me:
"The car has great fuel pressure and seems to run good other than have no power and stalling the car wont stall if you crank then idle up or feather the gas into gear it wont stall"
So to clarify:
1. You have an idle stalling problem?
2. Car runs great other than that.
If so,
1. Check EGR
2. Check for vacuum leaks
3. Check the electrical connection quality to the IAC.
Sounds like a big vacuum leak to me.
Old Mar 25, 2017 | 09:10 AM
Pat1990GTA's Avatar
Its mostly just a issue of stalling when going into gear...its like the iac cant compensate fast enough ?
It also doesn't seem to have alot of low end power
I will check again for vac leaks
The egr is brand new and vac line plugged up so i think it should be ok
Old Mar 25, 2017 | 09:52 AM
Engine: Lb9
Transmission: M20
Wonder if it's the park neutral switch, does rpm slightly increase in neutral ?
Old Mar 25, 2017 | 10:06 AM
Pat1990GTA's Avatar
Yes it does and according to the scan tool the computer is seeing park and neutral.
This is a very weird issue....im not sure where to go with it at this point. Im now leaning towards possibly a tranny/converter issue ( even though the converter is new) or even thought mby it was the lock up but unplugged that with no change.
I did notice the brake pedal felt kinda hard.......is it possiblethe brake booster has a internal vaccum leak cause the idle speed to be set incorrectly and then when the brakes applied to shift into gear the vaccum leak goes away and the iac cant keep up?
I donno just a crazy thought....i will have to investigate
Old Mar 25, 2017 | 10:36 AM
Engine: 350 TPI L98
Transmission: WC T5
That's what I'm thinking. Vacuum. Computers can't see it. And it's an idle RPM issue.
