Gear Change
Old Apr 8, 2017 | 03:23 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Gear Change
Ok guys, I'm about to swap in a Strange S-60 rear end and I'll be going from 3:23s to 3:73s. I plan on swapping the speedo gears later on, but I'm curious about how far off my speedometer will be with this swap until I get around to changing the speedo gears?
Old Apr 8, 2017 | 03:43 PM
GeneralDisorder's Avatar
Re: Gear Change
You can find out easily - just pull up any of the free GPS speedometer apps on your phone and when it says 50 MPH take the difference between your speedo, and 50, double it, and that's your percentage. So if your real speed via GPS is 50, and your speedo says 60, then that's 10 x 2 = 20% off.
As with any percentage it depends on how fast you are going. 0 is still 0. 100 is actually 80. And so on.
Personally I wouldn't mess with speedo gears. They aren't entirely accurate and you can wire in one of these and adjust your speedo for any gears you may change to in the future with the touch of a button:
http://www.dakotadigital.com/index.c...126/prd126.htm
Rick
Old Apr 8, 2017 | 04:01 PM
Car: 1986 IROC Z28
Re: Gear Change
Rick
That gadget is pretty sharp, but my old '86 has a speedo cable.
Old Apr 8, 2017 | 06:22 PM
Re: Gear Change
It'll be just about 3.73÷3.23 farther off that it used to be.
IOW it'll read about 15½% higher than it did before, at the same actual ground speed.
Old Apr 8, 2017 | 06:33 PM
skinny z's Avatar
Re: Gear Change
FWIW:
Finding the 43 tooth driven gear had proven to be difficult although this last go around, I stopped in at several transmission repair shops and a very kind proprietor had one in a drawer full of gears which he gave to me. Prior to that I had been driving using my stand alone GPS and memorizing the appropriate speedometer values.
File Type: doc
Old Apr 8, 2017 | 08:17 PM
Re: Gear Change
Huh. Interesting. My 86 Trans Am has electronic speedo. It's an Auto maybe that's the difference in 86.
I too looked at changing gears. But they are really hard to find it seems. I looked for a minute into doing that and couldn't immediately find any part numbers that weren't discontinued so I just got the electronic module.
Rick
Old Apr 8, 2017 | 08:43 PM
Car: 1986 IROC Z28
Re: Gear Change
Originally Posted by skinny z
FWIW:
Thanks Skinny............
Old Apr 8, 2017 | 08:48 PM
Car: 1986 IROC Z28
Re: Gear Change
Old Apr 8, 2017 | 10:20 PM
skinny z's Avatar
Re: Gear Change
You might be changing drive gears too from the looks of that chart.
