Low oil pressure cold start
Old May 15, 2017 | 10:27 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
So like the title says when I'm trying to start my car cold it takes a while for it to start firing. I noticed that it starts firing when the oil pressure gauge gets high. I don't have the cold start injector and if already replaced my oil pressure sensor. Is there a way to get oil pressure built up faster?
Old May 15, 2017 | 10:55 AM
GeneralDisorder's Avatar
Re: Low oil pressure cold start
Sounds like you aren't getting fuel pump power till you build oil pressure. The fuel pump prime relay gives fuel pump power during key-on and cranking, etc. Then the oil pressure switch takes over. I would be looking at the fuel pump relay and it's power source, etc.
GD
Old May 15, 2017 | 11:16 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I just replaced the fuel pump, fuel filter, and relay
Old May 15, 2017 | 12:57 PM
Do you have a test light or meter? You should check for power to the pump when you turn the key on (do not crank the engine). This will tell you if there is power there with key on and cranking before the oil pressure switch closes. It may not be the relay itself - could be the ECM isn't triggering it or it has no power going to it... etc.
GD
Old May 15, 2017 | 01:28 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I'll have to check that when I get home. I know it takes a while for the fuel pump to prime again if I turn the key to the on position and then turn it off then trying to get it to prime again for another cycle takes a while.
Old May 15, 2017 | 11:25 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I thought that was normal in thirdgens?
Old May 16, 2017 | 09:33 AM
There is a relay that is designed to kick on the pump at key-on, cranking, and for a bit after start to let it build oil pressure. Then the pressure switch takes over so if it's in an accident the fuel pump power will b cut by the loss of oil pressure.
GD
Old May 16, 2017 | 10:21 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Separate relay or the same relay?
Old May 16, 2017 | 10:44 AM
Engine: LB9
Axle/Gears: 3.08
I meant injectors firing is disabled until oil pressure comes up.
Old May 16, 2017 | 10:57 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
that's exactly what I want to fix
Old May 16, 2017 | 02:55 PM
It is? I wasn't aware the ECM had any oil pressure input.... are you sure? I'm going to check out the diagram on that one
GD
Old May 16, 2017 | 03:06 PM
Engine: LB9
Axle/Gears: 3.08
I am not claiming anything. I just remember seeing that somewhere on here.
http://www.corvettebuyers.com/c4vettes/l98.htm
Old May 18, 2017 | 04:01 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Injector firing is not related to oil pressure. My guess is you need a new chip to add in additional cranking fuel to help it start quicker.
Old May 19, 2017 | 07:54 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
You said you replaced the oil pressure sensor, what about the oil pressure switch? Last time I checked there was 2 switches-the oil pressure sensor that gives your gauge reading, and the oil pressure switch that actually runs the pump.
Old May 20, 2017 | 08:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Need to do some quick & easy trouble shooting. Get a fuel pressure gauge and attach it to the fuel rail port. Place it so that you can see it while you operate the ignition key/switch.
Do a key-on, engine-off (KOEO). The fuel pressure should rise to about 43 psi. After about 2 seconds the pump should stop and the fuel pressure should drop a little. It may also bleed off quickly, but the key here is to see if the pump runs at KOEO.
In the above test if the fuel pressure doesn't increase at KOEO, then the fuel pump relay isn't sending power to the pump. Start the trouble shooting there.
If the fuel pressure did get up near 43 psi, then tap over the ignition key to crank the engine for a brief period of time. The pump should run again for 2 seconds and bring the fuel pressure up. If so then the fuel pump, pump relay, and pump wiring is OK.
Do you know whether the ECM has the stock PROM in it? Or has it been tuned?
RBob.
Old May 20, 2017 | 08:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Be careful of that article, lots of incorrect information in it.
RBob.
Old May 20, 2017 | 11:05 AM
Engine: LB9
Axle/Gears: 3.08
RBob.
I never saw it before, only looked for where the oil pressure is linked to fuel pump and Google found that.
