dz302 hop up
dz302 hop up
would like to increase power of 69 z28 with stock dz 302. would consider building bigger short block and using stock heads and cam . need to preserve stock appearance and pick up a lot more torque and hp
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: dz302 hop up
Easiest easiest cheapest way is to put a 350 crank 3.48 stroke and pistons your current Pistons are floating pin you can use the rods with the 350 Pistons if you get pistons set up for floating pin and you'll have a 350 motor. both 302 and 350 are 4 inch bore
Car: 1983 G20 Chevy
Transmission: 4L60
Re: dz302 hop up
I built the same setup for a L-82 Vette a few years ago and used valve cover adapters on the Vortec heads. Sure it had the Vortec intake pattern but 99% of Chevy guys never even noticed.
Transmission: 4L80E/4L80E
Re: dz302 hop up
Would be interesting if it was related to the 3rd gen f-body platform.
But, it isn't.
But, it isn't.
83 Crossfire TA
Jun 17, 2017 08:50 PM
RoadRace
Jun 9, 2017 10:30 AM
