Car Hopping
Old Sep 5, 2001 | 03:45 PM
91RedFire's Avatar
Car Hopping
Whenever I lay some rubber down, my back tires start to hop and shake wildly. What could this be? I've heard that it is wheel hop, but how do I fix this?
1991 Pontiac Firebird
51k Miles
T-Tops
Fire Engine Red
305 TBI
Old Sep 5, 2001 | 07:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Either your car is putting out to much horsepower for your suspension or you need to replace worn out parts in the suspesion, at least that is my guess. I would not recommend doing wheel hops as it could destroy your rear.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 5, 2001 | 08:33 PM
82camaro's Avatar
Car: 82 camaro SC
How are the shocks, is it lowered, how are the rear suspension bushings, torque arm mount? When your tires are pushing forward, they are also moving up away from the pavement causing them to spin even faster, then they hit the pavement and it starts over again. This is very, very, bad on the whole driveline. Especially the axles. Mine got really bad after I lowered it. torque arm bushing helped, new shocks helped, LCA relocation brackets fixed the wheel hop.
Lots of power isn't needed for wheel hop. All you need is enough to spin the tires. Example, my wife's Sonoma pickup with 2.2L 4 cylinder(118hp) would wheel hop like crazy
Answer the above questions we can help more. Until you fix it, don't wheel hop.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 5, 2001 | 09:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The thing that will fix it is LCA lowering brackets. Lowering the car will make an already bad design even worse, to the point that some cars are almost undriveable under any significant amount of power.
ICON Motorsports
Old Sep 5, 2001 | 11:10 PM
91RedFire's Avatar
Well, I THINK this car could be lowered, because I bottom out on almost every speed bump I take. I have to go like 1mph over them, or I scratch my underbody. I wonder if it could be the suspension, but the car only has 51k and sat for 2 years. This is kind of weird.
51k Miles
T-Tops
Fire Engine Red
305 TBI
Old Sep 6, 2001 | 08:23 AM
bhaas's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
RB83L69 is right. I had the same problem. I installed some lower control arm relocation brackets and my wheel hop was gone. Car handled better to. Best bang for the buck. Install them NOW, you won't regret it.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Soon to be T5 YES!!!
[This message has been edited by bhaas (edited September 06, 2001).]
Old Sep 6, 2001 | 11:04 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I boxed in my control arms and my pan-hard bar. I noticed a significant increase, better traction. When I used to put it into reverse it would wheelhop if i gave it any gas (Once was enough). Now with my boxed in Control arms & pan-hard, It does not hop in reverse either.
I also installed subframe connectors from SSM. (don't know if that changed anything.
Somthing to consider. It cost me nothing more than the time to remove & install and a little time welding & painting.
John
Old Sep 6, 2001 | 06:31 PM
91RedFire's Avatar
Alright cool. Now where can I find these relocation arm brackets and how much do they cost? I better do this before I have to get a new drive train
51k Miles
T-Tops
Fire Engine Red
305 TBI
IroczFan
Oct 6, 2015 10:13 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
