Did I order the wrong oil pan? Timing cover? Gasket? All the above?
Old Jul 26, 2017 | 07:32 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ugh... this is not going well.
I have a 1984 L69 that I was freshening up before installing it in my Firebird.
I ordered a new oil pan and timing cover, as well as a gasket.
Went to install it all and the pan just won't fit over the gasket.
I had triple checked everything before ordering... so now I'm lost.
What did I order wrong? And what do I need?
Pan: http://www.ebay.com/itm/162253414624
Timing cover: http://www.ebay.com/itm/130744516087
Gasket: https://www.summitracing.com/parts/fel-os34510t
Just want to cruise again!
Old Jul 26, 2017 | 07:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Did I order the wrong oil pan? Timing cover? Gasket? All the above?
https://m.summitracing.com/parts/FEL-OS34509T/
Old Jul 27, 2017 | 06:57 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So there are only two, and I chose the wrong one. Seriously, that's the odds I've been dealing with since the start!
Old Jul 27, 2017 | 07:08 PM
Engine: Lb9
Transmission: M20
Looks like the pan was listed incorrectly
Old Jul 27, 2017 | 07:13 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Big surprise. Sorry for the dumb questions... but so can I not use the pan? Or do I just need the gasket you've posted to mate that pan to my block?
Old Jul 27, 2017 | 07:20 PM
Engine: Lb9
Transmission: M20
You just need a different gasket, there is a small front and large front seal looks like your pan uses the older style small one. Iirc 55-74 or so
Old Aug 3, 2017 | 02:13 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Thanks for the advice Tuned... that gasket (34509) fits the pan perfectly!
But...
the dipstick hole is on the wrong side.
So, third time's a charm. I need the 2-piece rear main seal, thin timing seal, and passenger dipstick hole.
Damn this is getting pricey. Anyone need one of these gasket sets? lol
Old Aug 3, 2017 | 02:35 PM
Engine: Lb9
Transmission: M20
Looks like these are the only gaskets made
Old Aug 3, 2017 | 02:53 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
huh. k. RTV it is I guess
Old Aug 3, 2017 | 02:59 PM
Engine: Lb9
Transmission: M20
Or ask if this is a thin front seal.
http://m.ebay.com/itm/Chevrolet-Smal...%257Ciid%253A7
Old Aug 3, 2017 | 03:07 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
oooo good find! I'll message them.
