305 barely idles. wont rev when in full throttle.
Old Jul 26, 2017 | 09:45 PM
91GTABIRD305's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.0 TPI
Transmission: 4 Speed Automatic
I finally got my 91 gta started after it had been sitting for 9 years. btw im 17 so the car had always been around and my fathers not a big car guy. I began working on it this summer. Replaced the distributor and all wires spark plugs, fuel pump and a fuel other gadgets. I finally got it started after hours of fighting with it. now it wont stay running unless im full throttle and dies off if i take off the throttle. i know its a fuel delivery problem. any ideas on what it may be?
Old Jul 26, 2017 | 09:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 barely idles. wont rev when in full throttle.
Varnished injectors !
Old Jul 26, 2017 | 09:53 PM
Engine: 5.0 TPI
if so, what should i do about that? thanks for the response boss.
Old Jul 26, 2017 | 10:00 PM
Engine: Lb9
Transmission: M20
You do t state if your dealing with a tbi or tpi or engine size but you should start with replacing them. I'm betting they are varnished with old fuel deposits.
305 tpi from your profile would use these
https://www.southbayfuelinjectors.co...tors-1985-1992
Old Jul 26, 2017 | 10:01 PM
Engine: 5.0 TPI
305 TPI 5.O. I will attempt to do that.
Old Jul 26, 2017 | 10:43 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
similar symptoms to clogged cat
Old Jul 26, 2017 | 11:19 PM
Engine: 5.0 TPI
so if i change the injectors and i believe im just going to get rid of the cat in general and it still wont rev, what should i look for.
Old Jul 26, 2017 | 11:26 PM
zed-028's Avatar
Verify the fuel pressure at the rail - poor pressure could be the filter or the pump's **** itself.
If thats all good then change out the injectors
If you want to test out the cat issue, disconnect it from the y pipes - stand back as its bloody loud.
Old Jul 26, 2017 | 11:28 PM
Engine: 5.0 TPI
just replaced both the fuel pump and fuel filter so i hope those wouldnt be it.
Old Jul 27, 2017 | 02:11 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Clogged cat and muffler with all kinds or crispy critters. Remember, it sat for a looooooong time, full of nuts and such
Old Jul 27, 2017 | 02:18 PM
Engine: 5.0 TPI
It has no cat as it was taken off.
Old Jul 27, 2017 | 02:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OK, what about the muffler? Anything coming out of it?
Old Jul 27, 2017 | 02:21 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Check your airbox and bellows for air restriction
Old Jul 27, 2017 | 02:24 PM
Engine: 5.0 TPI
Just a horrible smell whenever the car is trying to start starts
Old Jul 27, 2017 | 02:31 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I'll bet. I'm thinking the pipes and muffler are packed with nuts and stuff. I seen some stuff in my days......unreal!
Old Jul 27, 2017 | 02:45 PM
Engine: 5.0 TPI
How could i fix this?
Old Jul 27, 2017 | 03:02 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You can remove the pipe at the inlet to the muffler and blow that out. You muffler will have to be removed and replaced probably. Once you remove it at the inlet and it starts and runs, you'll know your muffler is packed.
Short story:
Years ago, my Wife's 305 5spd T/A's Cat clogged. Wouldn't get over 35 mph. Replaced cat. Car ran good for 2 days. Next day had the muffler replaced. All the chunks from the cat clogged the muffer.
Old Jul 27, 2017 | 09:11 PM
zed-028's Avatar
I had a clogged muffler (cat was hollowed out so no restrictions there) and was running cc carb and cc dist which always ran rich.
rear muffler was packed with about 8kg of fine black soot. Only a partial blockage but enough to cause similar issues
Old Jul 27, 2017 | 10:35 PM
Engine: 5.0 TPI
muffler delete it is!
