what did you do to your thirdgen today?
Old Jan 2, 2018 | 11:01 PM
  #301
2 birds 1 Z's Avatar
Car: 2002 Firehawk & ws6 1989 Iroc Z
Engine: All 3 have 350s
Transmission: Birds manual Iroc auto
Axle/Gears: TAs 342 & Iroc who knows?
Re: what did you do to your thirdgen today?
Originally Posted by Evilokc
I colored over it yesterday. it served its purpose by spreading joy to the masses. it earned its rest
I bet you got some strange looks when you had it. Never seen anything like that before myself. Pretty creative.
Old Jan 4, 2018 | 05:36 AM
  #302
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
rushed home from work to try and correct the coolant leak in the bird. figures I would wait until its 3 degrees to almost overheat the car. I checked all the hoses and they seemed fine. noticed a little puff of something out of the cap. replaced the radiator cap. drove it for 33 minutes without issues. I hope that was the fix.
Old Jan 4, 2018 | 04:16 PM
  #303
Evilokc's Avatar
Engine: tbi 305
drove the 40 mile round trip to work without any coolant issues. I'm gonna call that fixed.
Old Jan 5, 2018 | 10:34 PM
  #304
Evilokc's Avatar
Engine: tbi 305
ordered a hood safety latch spring. so hopefully my hood will actually pop up when I pull the hood release.
Old Jan 5, 2018 | 10:50 PM
  #305
When my hood is released, it barely raises up. I can't tell either way from behind the wheel. Also, have seen vids where guys can just press their hoods shut with a click. I have to slam mine to get it to latch.
Old Jan 6, 2018 | 04:49 AM
  #306
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
sounds like its out of adjustment
Old Jan 6, 2018 | 12:47 PM
  #307
Evilokc's Avatar
Engine: tbi 305
once I actually have a spring in there it will probably need some sort of adjustment.
Old Jan 11, 2018 | 09:35 PM
  #308
Wanted to drive the Iroc to work Friday, but decided not to, because of the 60% chance of thunderstorms tomorrow. GRRRRRRRRRR!
Old Jan 12, 2018 | 06:55 PM
  #309
Evilokc's Avatar
Engine: tbi 305
received my hood spring today. doing an oil change tomorrow and hope to install it then.
Old Jan 12, 2018 | 07:10 PM
  #310
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
I feel like such an underachiever, lol! Already almost half thru winter and haven't done crap Got a couple extra bucks left over from Christmas, think I'm gonna order a 3.70 gear set this week.
Old Jan 12, 2018 | 07:22 PM
  #311
Evilokc's Avatar
Engine: tbi 305
I decided a month or two ago that I was going to dedicate most of my efforts on my truck. I will do whatever needs to be done to keep the firebird running well though.
Old Jan 12, 2018 | 07:35 PM
  #312
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
I had my NC inspection done today. Will be getting my tags next week and start driving it again. Need to finish a little body work and into the paint booth. Been a long time coming.
Old Jan 12, 2018 | 08:26 PM
  #313
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Stripped my other set of crosslace wheels so I can run 4 fronts and have the same offset on all 4 corners. I used our brake lathe to sand the outer lips. Got them primed and painted. I will clear the gold this week and then polish the outer.
Old Jan 12, 2018 | 08:57 PM
  #314
NoEmissions84TA's Avatar
Great work.
Old Jan 12, 2018 | 10:05 PM
  #315
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
nice i like the brushed look.
Old Jan 12, 2018 | 11:20 PM
  #316
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
It’s not so much what I did today, but what I’m about to do... This arrived the other day.
Old Jan 13, 2018 | 09:57 PM
  #317
Evilokc's Avatar
Engine: tbi 305
to quote Joe Dirt.. "DAAAANNNG"
Old Jan 14, 2018 | 12:12 PM
  #318
Evilokc's Avatar
Engine: tbi 305
did an oil change yesterday. probably the first one its had in 5 years. added some cleaner to help de-sludge the motor. its leaking somewhere. looks like it was near the filter so I'm hoping the oil change fixed that but I'm not sure yet. after the oil change was done I spent some time cleaning off the oil on the undercarriage so I will be able to see where its leaking from.i was pretty happy at the condition of the underside of the car. yes it had oil on it but other than that it was pretty nice. no rust or torn up sections.
Old Jan 14, 2018 | 01:19 PM
  #319
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Be sure and clean the inside of the bead where the tire seals. Looks a bit crusty and sure will leak sometimes.
Old Jan 14, 2018 | 02:48 PM
  #320
Evilokc's Avatar
Engine: tbi 305
had the car out running errands and noticed a small puddle under the car. very small. it didn't look like oil though. I popped the hood and I believe I'm still leaking powersteering fluid. the steering box is COVERED in fluid. not positive where its coming from but I'm going to start looking for it. happy that I didn't see any oil leaking though. maybe that's fixed.
Old Jan 14, 2018 | 02:52 PM
  #321
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Thanks for the tip! It may sound crazy but I think I will put them back on the lathe and sand the inside and the backside. Contemplating either coating or painting the backside as well. Any thoughts or ideas are welcomed.
Old Jan 14, 2018 | 06:21 PM
  #322
Polish the lip & the barrel. Black or dark barrels make the wheel look dirty back there. Paint the laces black.
Old Jan 22, 2018 | 10:53 PM
  #323
Evilokc's Avatar
Engine: tbi 305
well looks like I fixed my oil leak. that's always good. now I just have the stupid power steering leak. 100 leaks down 1 more to go.
Old Jan 27, 2018 | 10:52 PM
  #324
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Jbuchanan those rims look great! I should have redone mine when I done my paint I was just worn out from that whole deal.
Old Jan 27, 2018 | 11:07 PM
  #325
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Appreciate that especially coming from someone that can lay paint like you. Here is a pic of light polish, I'm about to go heavy.
Old Jan 27, 2018 | 11:51 PM
  #326
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Fresh rubber!
Old Jan 30, 2018 | 09:09 AM
  #327
Vmenojr's Avatar
Car: 1992 RS convertible
LEDs put in! Made all 4 lights low beam/high beam
Old Jan 31, 2018 | 05:09 AM
  #328
That's not a bad idea.
Old Jan 31, 2018 | 09:31 PM
  #329
That's a cool looking sky.
Old Jan 31, 2018 | 10:06 PM
  #330
Vmenojr's Avatar
Courtesy of the San Francisco Bay Area
Old Feb 4, 2018 | 02:31 PM
  #331
Evilokc's Avatar
Engine: tbi 305
last weekend I decided to install my hood latch spring. it didn't go as well as planned. there are 4 tables that bend over the bottom coil and hold it in place. 2 of them were badly broken and fell off as soon as I touched them. I had other projects so I abandoned the job. I'm sure I can figure something out to make it work. not having a spring to pop the hood up is a pain.
Old Feb 4, 2018 | 06:28 PM
  #332
Would a cable tie work? Along with the other 2 good tabs, of course.
Old Feb 5, 2018 | 08:21 PM
  #333
Evilokc's Avatar
Engine: tbi 305
probably. I will look into it next time I'm working on it. that will be a couple of weeks.
Old Feb 6, 2018 | 09:58 PM
  #334
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Got my wheels done, sorry about the dirty car. Love having four fronts as the deeper offset looks better imo. Now I got to redo my decals so the color will match up.
Old Feb 11, 2018 | 01:36 PM
  #335
Evilokc's Avatar
Engine: tbi 305
I have been ill for about 9 days now. I'm over the flu but haven't gotten my strength back yet. so this weekend is more sitting around than getting anything done. however I had to move my car and I noticed that there is no oil puddle under it. I know not having an oil leak may not seem like a big deal for you guys with pristine cars. however when I bought mine every fluid leaked. took forever to track down the coolant , fuel, trans, then finally oil leaks and get them fixed. I haven't fixed the power steering leak yet but that's the last one. its the simple things like stopping my car from bleeding to death in the driveway that keeps me going.
Old Feb 13, 2018 | 10:58 PM
  #336
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
replaced the steel driveshaft with an aluminium one which removed 50% of my vibration, unfortunately this left me with the other 50% which can be attributed to a slightly bent axle flange...
i would have rather gotten rid of that particular vibration first but im taking it as a win!
Old Feb 18, 2018 | 09:43 PM
  #337
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Put some new hood struts on her first thing after lunch. Later Cursed at it after shifter cable had came loose and left me stranded right before a rain. I eased it back into place and put it back in the shop i will get a cotter pin and fix her up one evening.
Old Feb 24, 2018 | 11:14 AM
  #338
Removed the hazy gage cluster lens cover, cleaned & polished it back to a nearly new appearance. The bezel that holds it in place made some rather deep scratches that are hidden. 29 years of dry wiping created scratches that polished out nicely. At last, the windows are clear again.
Old Feb 24, 2018 | 07:25 PM
  #339
KanzlerBismarck's Avatar
Car: '89 Iroc 5.7
Axle/Gears: G80 Posi/LS & GH3 2.77
I love it!
I installed my Ram Air, and continue trying to troubleshoot my MAF.
Then took her to the pillars of Hercules.
Old Feb 24, 2018 | 07:32 PM
  #340
Man, I LOVE the 2nd gen Iroc wheels.
Old Feb 26, 2018 | 10:42 PM
  #341
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Makes it feel like a new car when you glance down at the gauges, doesn't it?
Old Feb 26, 2018 | 11:01 PM
  #342
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Fixed my shifter cable. Adjusted my t\v cable to soften up the harsh 1-2 shift. All ready for cruise- in this wkend
Old Feb 26, 2018 | 11:19 PM
  #343
Evilokc's Avatar
Engine: tbi 305
I may have fixed my power steering leak. I put a new hose clamp on and put some fluid in. had my p.i.c start the car and turn the wheel in both directions several times while I watched for a leak. I saw nothing. it was a little dark to be sure but I didn't see anything. will know for sure after driving for a couple of days.
Old Mar 3, 2018 | 08:39 PM
  #344
Man, you can say that again. Wasn't even thinking about it & looked down to check speed & was quite impressed at the clarity of the lens faces. Well worth the effort to polish.
Old Mar 3, 2018 | 09:18 PM
  #345
Ordered new parking lights to complete the front. Fogs, headlights, grille & under hood insulation are all new. Got new side mirror glass because the driver's side is scratched. Polished the age haze off the tail lights to make them like new again.
Old Mar 4, 2018 | 12:44 AM
  #346
Car: '89 Iroc 5.7
Not today, but over the last 3 days, I removed & reclamped the armrests, which were bowed. Before pics.
Yuck, gotta go. Here are a few clamping pics.
Driver's side. Did this 1st. Scrap piece of particle board with a towel to prevent marring of the rubber.Plastic was scuffed up with 600 grit sandpaper. I put a death clamp on here.
The rest of the dr. side. Again with the death clamp.
Dr. side installed. As you can see, the death clamp was over kill. It made the top surface wavy. I'm not to concerned about it, as it looks tons better than before. I'm not gonna show the car with the doors open anyway.
Death clamp close up.
Pass. side had a small area underneath that I addressed & the top was one, long bow.
Here it is, all clamped, lightly this time
Pass. side installed. Again, much better. Lighter clamp pressure resulted in a smooth surface. Overall, an easy job to do. I used Shoe Goo for the adhesive with a minimum 6 hours clamped. Both tops were left overnight. The hardest thing was trying to remove the caps at the top, leading edge, to get to the bolt underneath. Got the headliner done Wednesday & the upholstery shop didn't have enough suade to do the visors & sail panels. I went back today to get those finished pieces installed. Will post pics in the morning.
ahhh.. so that is how it's done...
I need to do this to mine.
Old Mar 4, 2018 | 07:33 PM
  #347
The hardest part was removing the circular plugs at the leading edge of the door pull without messing them up. I ended up taking the car to get the headliner replaced at an upholstery shop, & had them remove the plugs. They have experience doing that kind of stuff.
Old Mar 13, 2018 | 07:27 AM
  #348
Evilokc's Avatar
Engine: tbi 305
drove mine to work and back. still running well and not leaking anything at the moment. that's cool to me.
Old Mar 13, 2018 | 06:51 PM
  #349
Drove mine to work, as well. No rain in the forecast. Will drive it the rest of the week. It's laughing at my 2 Trans Ams saying, "Ha Ha, he's driving me." The birds reply, "At least we both still smell like new inside." Which they do. If I could have afforded the insurance in 1988, I would have one from new. I wonder if I could prolong the new car smell for 30 years. That would be something.
Old Mar 13, 2018 | 09:23 PM
  #350
Evilokc's Avatar
Engine: tbi 305
they sell new car smell air fresheners.
