Rough idle
Old Sep 28, 2017 | 12:38 PM
88guy's Avatar
Rough idle
Hey guys new to the site been reading a while here is i just bought a 88 formula350 178,000 for 500 its been sitting 9 years i drained tank new fuel pump and filter and full tune up new temp sensor and cleaned maf hit the key it fires up then dies if u play with throttle a little after it popps back through intake it will idle but hit gas and dies after about 20min of running idle drops to bout 650 check engine light goes off and car pures like a kitten with no problems left fan also comes on with key and can not pull any codes even tho check engine light is on till after 20 min or so it is also a one owner car a woman and does not apear then anything has been tamperd outside of stock any help would b great im stuck
Old Sep 28, 2017 | 12:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Rough idle
The fan coming on with the key sounds like a bad ecm or someone required the fan. You don't state if this is efi but it would be a good idea to have your injectors serviced or replace them.
Old Sep 28, 2017 | 12:58 PM
88guy's Avatar
Re: Rough idle
I was hopeing the later on the fan or maybe stuck in diagnostic mode its a 88 with 5.7 tuneport i thought the injectors but would they jus suddenly start fireing fine after about 20 min because after that is runs great no issues thanks
Old Sep 28, 2017 | 01:11 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Since the check engine light is on and goes off other than normal operation light on until start sounds like a bad 1227165 ecm. Running injector cleaner to help clean the filter baskets wouldn't hurt but sounds like the ecm is the primary issue. Especially if you can't pull a code 12 if that's the case.
Old Sep 28, 2017 | 01:19 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
You can see the ecm grounds the green/white wire at 226f or so. If it's wired correctly the ecm would not run the primary fan until then.
Old Sep 28, 2017 | 01:22 PM
88guy's Avatar
Re: Rough idle
I ran seafoam in 5 gal of fresh 91 fuel but havent ran on road tires are dry but running in garage almost empty now th check engine light stays on till after the idle smooths after about the 20 min mark and no not even a 12 code will display. Sry not up on all sensor lingo im used to the old 70s i know what the ecm is but whats 1227165 ?
Old Sep 28, 2017 | 01:26 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
The 165 is the ecm (electronic control module) service number it might have a superseded number like 16198259 , 88999194 or cardone 77-7165
Old Sep 28, 2017 | 01:31 PM
88guy's Avatar
Re: Rough idle
Ok do u have or kno where i can get a wireing diagram of the ecu so i can check grounds and connections before 400 on a new ecu thanks
Old Sep 28, 2017 | 01:33 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Wow where are you looking at a $400 ecm that's nuts
https://m.ebay.com/itm/Engine-Contro...%257Ciid%253A1
http://tpiparts.net/1227165_pinout_diagram
Old Sep 28, 2017 | 01:39 PM
88guy's Avatar
Re: Rough idle
Oh wow i was looking at autozone lol
Old Sep 28, 2017 | 01:43 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
The grounds are behind the passengers side cylinder head. But with your symptoms sounds like a bad ecm to me. I have soaked injectors in sea foam and wasn't impressed bye the amount of varnish it can or can't remove.
Old Sep 28, 2017 | 02:26 PM
88guy's Avatar
Re: Rough idle
What do you recomend for the injector cleaner
Old Sep 28, 2017 | 02:46 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Chevron or stp
Old Sep 28, 2017 | 03:04 PM
88guy's Avatar
Re: Rough idle
Thanks would u happen to kno what sensor is inbetween the back two plugs on the passenger side its a single wire single pin connector i just found the connector is broke
Old Sep 28, 2017 | 03:07 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
That's the secondary fan switch. Same as knock sensor connector.
https://m.ebay.com/itm/GM-Knock-Sens...%257Ciid%253A1
Old Sep 28, 2017 | 03:28 PM
88guy's Avatar
Re: Rough idle
That wouldent b keeping the fan on would it?
Old Sep 28, 2017 | 03:29 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
If that connector is grounded the secondary fan will kick on.
Old Sep 28, 2017 | 03:36 PM
88guy's Avatar
Re: Rough idle
Ok thanks for all your help im gonna put the ecm in in the morning just orderd it i will let you kno what happens
Old Sep 28, 2017 | 03:41 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Disconnect your battery before you disconnect the ecm to avoid electrical static discharge/ voltage spike. You will need to remove the memcal. Blue covered computer chip. Tilt back the white and blue retainer catches. The memcal can only be inserted one way.
Old Sep 28, 2017 | 04:50 PM
88guy's Avatar
Re: Rough idle
Thanks i forgot to mention it idles at about 1300 till that 2omin mark and its rich and oil pressure reads 60 dont get bk to normal till that 20 min mark and what is this?
Old Sep 28, 2017 | 04:52 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
That's a vss buffer vehicle speed sensor signal buffer for the speedometer and ecm.
The oil pressure maybe the sender itself or gauge is reading off.
The buffer mounts on a tab on the ecm holder.
Old Sep 28, 2017 | 05:07 PM
88guy's Avatar
Re: Rough idle
Ok ill try the oilpressuer sending unit to but it reads norm after hot could that cause it to run the way it does looks like someone at some point has already got into the comp area cuz that was hanging loose in dash and some screws where missing on pannel
Old Sep 29, 2017 | 12:05 PM
88guy's Avatar
Re: Rough idle
Ok replaced ecm now car wont start is there some sort of programming i have to do
Old Sep 29, 2017 | 12:13 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Did you swap in the computer chip ?
Old Sep 29, 2017 | 12:16 PM
88guy's Avatar
Re: Rough idle
Yes and last night before i took the old ecm out i tapped on it with my hand while it was running to c if it was bad and it killed the engine and wouldnot start bk up so i figured that ment it was bad now that new ecm is in it still wont start but i can get a 12 code now
Old Sep 29, 2017 | 12:18 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Check the fuse next to the battery I think it's a 20amp fuse.
Old Sep 29, 2017 | 12:22 PM
88guy's Avatar
Re: Rough idle
Its good
Old Sep 29, 2017 | 12:25 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Start back at the basics, do you have spark. Do you have injector pulse (noid light).
Fuel pressure good.
Old Sep 29, 2017 | 12:26 PM
88guy's Avatar
Re: Rough idle
It will fire and then die immediatly
Old Sep 29, 2017 | 12:29 PM
88guy's Avatar
Re: Rough idle
Could it have killed a sensor like iac,tps or icm
Old Sep 29, 2017 | 12:34 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
You might want to pull a few plugs to see if it's flooded or dry plugs.
To clear out a flooded efi hold the gas pedal to the floor and crank. Sounds like lack of fuel injectors plugged . The ninth injector works on cold startup it might be the other eight not firing.
Old Sep 29, 2017 | 12:37 PM
88guy's Avatar
Re: Rough idle
Ok im just confused because it was running until i tapped on the old ecm then when i tried to fire up it did what its doing with thus new ecm
Old Sep 29, 2017 | 12:55 PM
88guy's Avatar
Re: Rough idle
Awsome it was flooded got it running but still rich only code is a 34 low voltage to maf i believe i already cleaned maf what els could it be ur help has been amazing i thank you so much the ecm would have been last thing i replaced u saved me so much time and money
Old Sep 29, 2017 | 12:59 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
http://www.chevythunder.com/maf_code_34.htm
Old Sep 29, 2017 | 01:08 PM
88guy's Avatar
Re: Rough idle
Thank you so much getting a 33 and 34 maf must b bad looks like jus a lil more money that must b whats making her run rich thank you
Old Sep 29, 2017 | 01:22 PM
88guy's Avatar
Re: Rough idle
Actually intake hose wasent tight just tightend it and no more code
Old Sep 29, 2017 | 01:37 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Great progress
Old Sep 29, 2017 | 01:40 PM
88guy's Avatar
Re: Rough idle
Thanks again couldent of done it without ya
Old Sep 29, 2017 | 01:42 PM
Engine: Lb9
Transmission: M20
Re: Rough idle
Welcome
