87 TPI Iroc camero wont start after sitting
Old Oct 25, 2017 | 04:49 PM
Lostboy's Avatar
I have a 87 TPI Iroc Camero that was running fine and then sat for over a year and now wont start. It has fuel up to the rails and it will start if I squirt fuel in the intake but then dies. It runs as long as long as I spay fuel in the intake. I am getting fuel up to the TPI but that is as far as it goes. What would be the most common thing and so forth. Thank you
Old Oct 25, 2017 | 04:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 87 TPI Iroc camero wont start after sitting
Did it have stale fuel in it ?
Old Oct 25, 2017 | 05:13 PM
Lostboy's Avatar
All the fuel was drained and it has fresh fuel all the way to the rails, The fuel pump is also in good condition with good pressure.
Old Oct 25, 2017 | 05:21 PM
Engine: Lb9
Transmission: M20
Injector pulse checked with a noid light ?
Have you tested actual fuel pressure ?
Last edited by Tuned Performance; Oct 25, 2017 at 06:31 PM. Reason: More questions
Old Oct 25, 2017 | 05:41 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I would guess your injectors are not functioning. Like tuned said check to make sure you have injector pulse.
Old Oct 25, 2017 | 05:55 PM
Lostboy's Avatar
I will pick up a noid light and check that tonight, I did a ohm test and had 17.1 at all injectors except one which was 20.1 but will check with a noid light and post my findings. Thanks for the fast reply's guys
Old Oct 28, 2017 | 11:14 AM
Lostboy's Avatar
I picked up a noid light and I am NOT getting a pulse to the injectors. Not sure why it would lose pulse from just sitting as it ran fine before.
Old Oct 28, 2017 | 11:30 AM
Engine: Lb9
Transmission: M20
It might be the icm regardless that you have spark. The purple/white wire that goes to the ecm controls injector pulse. Check your injector fuses.
Old Oct 28, 2017 | 03:21 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
it's an FI issue. i had rats chew the wires on my 86 bronco. pissed me right off. i din't notice at first and replaced both fuel pumps. the entire harness was destroyed feeding electricity to the injectors.
TrevinE
Mar 30, 2019 09:01 AM
ScarabChris
Oct 26, 2017 03:54 PM
sack23
Oct 24, 2017 11:29 AM
86konaz28
Oct 11, 2017 06:14 PM
DSG87
Aug 9, 2017 03:59 PM
