Transmission pan, cross member
Old Jan 26, 2018 | 07:14 AM
Smackdown's Avatar
Car: 88' GTA & 89' T/A
Engine: 350 TPI & 305 TBI
Transmission: Automatic
I want to change my transmission oil pan, filter and oil. Problem: I cant get to loose these bolts under the crossmember. Someone said to me, I should support it with a jack while unbolt the crossmember. But where exactly do I have to put the jack on, cause I dont want to have everything dropped lol Can someone help me, what is the easiest way?
Old Jan 26, 2018 | 07:39 AM
Smackdown's Avatar
Re: Transmission pan, cross member
Can I jack it up right behind the crossmember? (top of the 2nd picture)
Old Jan 26, 2018 | 09:36 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I would just support right behind the crossmember on the tailshaft area of transmission with a jack and remove the crossmember for easier access since its only a few bolts to remove, jsut make sure jack pad has tailshaft secured so it wont slip off jack pad.
Old Jan 26, 2018 | 10:09 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use a short socket and extension to get to the bolts.
Old Jan 26, 2018 | 10:59 AM
Smackdown's Avatar
I got it done, thanks. Those ****ing stock gaskets are such a pain in the *** to remove OMG! But I did it after 2 hours...
Old Jan 26, 2018 | 06:15 PM
NoEmissions84TA's Avatar
Good job. You did it right by using a couple of bolts as a hinge to let the fluid out of the pan as your picture shows. There is nothing worse than a whole pan of transmission fluid coming down all at once.
What TTOP350 said is correct: I use a short socket and extension to get to the bolts.
1/4" drive does the trick. If you wish, now you can remove the cross member and grind
some notches to make this job easier in the future.
Old Jan 26, 2018 | 07:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
A swivel socket works well
Blake
Feb 22, 2007 10:33 PM
87ROCZ
Feb 20, 2003 04:04 PM
87ROCZ
Feb 18, 2003 01:19 PM
downwithET
Aug 22, 2002 01:42 AM
Twilightoptics
Jun 16, 2002 09:47 PM
