Age old horsepower question
Car: 1991 Trans Am
Transmission: 4L60
I just installed headers and I'm curious. Could someone look at my sig and tell me what kind of horsepower you think I'm pushing? Desktop Dyno 2000 says 295 hp and over 400 ft lbs of torque. I know full well the torque numbers are ridiculous (I've heard that about DD 2000's torque numbers), but is the hp close?
Car: 99 Formula
Axle/Gears: 342
Originally posted by firbird
here is another age old horsepower question
does mothballs raise compression
lol
lol
actually the moth ball trick does work, but i wouldnt do it on a FI car, as for the origanal question, desktop dyno figures in a fresh new engine with all the good stuff (all clearances correct, roller rockers,..etc) they dont have a setting for log manifolds and y-pipe only duels, it doesnt factor in tired, beat on 10-15 plus year old engines. it is very accurate when eveything is put in correctly. i've seen 3 seprate dyno sheets to the desk top dyno and all were within 5 HP
Car: 1991 Trans Am
Transmission: 4L60
BWAHAHAHAHA @ poor moths
DD2k can be very accurate...but you have to enter EVERYTHING accuratly. The exact cam specs, the real flowbench numbers for your heads, and realisticly low numbers for TPI intake cfm.
Desktop dyno exaggerates the power added from headers a lot, although it does a decent job of creating the tuned port torque and horsepower curves. This is probably because you can only choose "small tube headers with mufflers" instead of "edelbrock tes headers."
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
In dtd when you pick the type of cam, pick hyd for a factory hyd roller. The factory rollers' lift curve is no more intense
then a flat tappet hyd.
Accuracy is also improved if you enter the actual seat running
duration instead of the .050" numbers.
This "seat duration" can and does vary widely from the published specs.
DTD also always assumes the exhaust system and airfuel ratio is of perfect optimized design, which is rarely the case in the real world.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can pick up Camquest for all the accurate cam specs. It contains about 3500 different grinds.
As mentioned above, DD2000 is only as accurate as the data that's inputed. Garbage in, Garbage out. It's no different than using a G-Tech. Input wrong numbers and get wrong results.
As for the mothballs:
http://newton.dep.anl.gov/askasci/chem00/chem00485.htm
Car: 4
Engine: 6
Transmission: 5
Like f-bird said, the factory's roller cams are no more intense than their flat tappets. They didn't manage to figure out that part of the benefits of a roller system. They simply transferred their lame grinds such as the "peanut" cam onto a roller blank. What a shame.
I'd suspect that the addition of headers by themselves would have increased your engine's output by no more than 20 HP, and probably less than that. However, it's the best first mod for these cars, without which you won't get the full benefit of anything else you do.
Mods don't just "add up" like some people would like to believe. Some things do almost nothing by themselves, but only work together in combination with other things. Headers work together with other things that improve flow: in the case of these motors, cams and heads, particularly. Change any one of those things and you don't get all that much. On the other hand, change all 3 of them as a matched group, and you can get tremendous improvements.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
diana227vegas
Jul 8, 2016 12:27 AM
