Vacuum lines
Old Mar 20, 2018 | 02:54 PM
onebdgti's Avatar
Vacuum lines
I bought my 87 Z28 with a swapped 383 in it. The previous owner cut the 2 hvac vacuum line going through the firewall. Does anybody know what these to lines control?. I figure one is for the blend doors and the other is for A/C.
Old Mar 20, 2018 | 03:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vacuum lines
I’m not sure what the second line is for I think there is only one line for the hvac.
Old Mar 20, 2018 | 05:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Vacuum lines
One line goes from engine (vacuum), thru the firewall, to Hvac controls. The other comes from the hvac full cold (hot cold/selector) valve and goes back thru the firewall to the heater control valve (to bypass the heater core).
Old Mar 20, 2018 | 07:07 PM
Re: Vacuum lines
What dead said.
One is vac supply to the HVAC control head; the other is vacuum from the control back out to the heater control valve.
Old Mar 20, 2018 | 07:23 PM
Engine: Lb9
Transmission: M20
Re: Vacuum lines
I sounds like the po removes a lot of things. If the heater valve is still there here is what it looks like.
Old Mar 20, 2018 | 07:29 PM
onebdgti's Avatar
Re: Vacuum lines
Ahhhh mine doesn't have a heater control valve. Guess its time to get one.
Old Mar 20, 2018 | 07:31 PM
onebdgti's Avatar
Re: Vacuum lines
Yeah he removed all kinds of stuff. I mean if its a street/strip car make sure the heater works.
Old Mar 20, 2018 | 09:26 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Vacuum lines
If you cant find one, just run the lines directly from the waterpump and skip the control valve. Itll be just like almost all of the other cars out there that circulate thru the heater core when the pump is turning.
Old Mar 20, 2018 | 09:36 PM
Engine: Lb9
Transmission: M20
Re: Vacuum lines
Rock auto has them
https://www.rockauto.com/en/catalog/...ter+valve,6860
jstratouly
Sep 12, 2014 09:21 PM
MechCD
Aftermarket Product Review
May 5, 2005 10:09 AM
steve8586iroc
Mar 26, 2004 01:00 AM
86TpiTransAm
Nov 27, 2001 07:18 PM
