Idle Knock: Listen and Comment
Old Mar 31, 2018 | 11:31 AM
skinny z's Avatar
For the record this is the same 350 I've had for years in various iterations. The latest is with fresh cylinder heads, XR288HR (advanced 4°), .030" shortblock with high-ish mileage (re-ring/re-bearing about 30k miles ago).
Compression test results not great but OK.
Leakdown test was miserable.
In fact the results are so bad, with the engine generally running really well up to the point of misfire (5000 RPM) , that I'm thinking I may have screwed up the test procedure.
Anyway, I shot this video and with good audio, you can hear the knock I'm trying to hunt down. It's definitely isolated to the front of the engine, topside. I had removed all of the belts and the noise is the same. It's not in the valvetrain although the "sewing machine" clatter of the all roller setup is clearly audible.
Here are a couple of threads I started while going through the testing.
At the moment, it starts, idles and drives really well. No smoke.
https://www.thirdgen.org/forums/tech...-odd-high.html
https://www.thirdgen.org/forums/tech...oil-drain.html
And the video: (Please forgive the vertical format)
Old Mar 31, 2018 | 11:36 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Idle Knock: Listen and Comment
Vid Not Available.
Old Mar 31, 2018 | 11:37 AM
Vader's Avatar
Same here - The video seems to be deleted.
Old Mar 31, 2018 | 11:40 AM
skinny z's Avatar
Hmm. The video works for me.
I'll have to check the settings.
Old Mar 31, 2018 | 11:48 AM
skinny z's Avatar
Maybe now...
Old Mar 31, 2018 | 11:54 AM
skinny z's Avatar
Old Mar 31, 2018 | 12:37 PM
skinny z's Avatar
Seems that the settings are OK now as they were set to private before.
Let me know.
Old Mar 31, 2018 | 01:16 PM
Vader's Avatar
Video works for me now.
It almost sounds valve-ish.
Old Mar 31, 2018 | 01:46 PM
skinny z's Avatar
Playback through my computer's speakers makes the sound more like a thud than a tap normally associated with lifter/valve/lash noise. Still I wouldn't discount anything although I've set the lash more than once and as far as I can tell, it's good. Valve job, intake valves and guides are new. Valvetrain geometry is spot on.
I'm thinking maybe there's something up with the timing chain set or the cam thrust button (it's a retro-roller).
I have to keep the vehicle more or less intact so it can be moved around so it's not going to coming apart anytime soon other than to test the valve springs as they might be related to the misfire at RPM.
And if the shortblock really is toast, the noise could be a piston bouncing around.
I running a chokeless carb and the cold starts really dump a lot fuel in the cylinders. There may be a lot of cylinder wear to add to the problem. Hopefully it's not a rod going away.
Old Apr 1, 2018 | 10:38 AM
skinny z's Avatar
Kind of asking myself questions here: If the cam button has backed off and the cam is walking back and forth in the tunnel, wouldn't that upset the timing as well? Because the timing is rock steady. At least at idle it is.
Old Apr 2, 2018 | 07:47 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Does the noise diminish somewhat as it warms up? If so, I'd say it's piston noise.
I have an old pickup with a 330k mile very worn out engine, makes a similar noise for ~20 seconds after a cold startup, then almost goes away. And that 20 seconds of noise turns into well over a minute on winter cold startups. I've been driving it for over a year like that, just using it like an old truck; no romping on it, WOT shift points turned down to 4k
Old Apr 2, 2018 | 01:17 PM
skinny z's Avatar
My memory of the engine warmed up is pretty fuzzy seeing as it's been a few months since the car has been on the road.
I've also suspected piston noise and with the results of the leakdown test combined with a fresh valve job leaks me to believe the bores, pistons, rings might be whacked.
I've never determined where the fragment that was stuck to the drain plug came from (the engine has been kept a runner and will stay that way until replacements are ready to go) . I can't see how its possible for a chunk of a pistin ring could make its way to the pan without mangling either the piston, the cylinder bore or both. If it IS a ring fragment, then that would explain a lot.
And almost certainly the knock, fragment and misfire are all related.
Old Apr 5, 2018 | 08:58 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Usually (not always) a rod knock will deminish or even go away if you pull the affected cylinder plug wire. Have you tried this?
Old Apr 6, 2018 | 07:49 AM
skinny z's Avatar
That's not a bad idea actually and something we did back in the day when I first started hot rodding. That's how we diagnosed my friend's SBF bottom end problem.
I think the plan might be (when the warm finally arrives) is to get the engine up to temperature and run all the tests again. Including the plug wire deal. It's the leakdown results that were most alarming and I think that alone is worth revisiting.
IH8Fords
Sep 9, 2024 05:39 PM
AirwolfPL
Jul 10, 2008 08:41 AM
9D1BURD
Sep 21, 2006 08:35 AM
JPrevost
Apr 23, 2002 09:43 PM
