SMALL RUST SPOT IN CYLINDER, WHAT TO DO??
Old Apr 14, 2018 | 05:35 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Got the heads pulled off a motor I'm working on. Everything looked good until I found a little spot of surface rust in one cylinder about the size of a q-tip head. Was just at the top of the piston ring travel. Sprayed some wd40 on a rag and rubbed it off. Should I be worried about it?? Motor spins freely, and didn't see any score marks in the cylinder. I'll take a flashlight to it in the morning tho for a better look. I do not wanna do a full motor build for this truck, but I also don't want any issues a year or 2 down the road after doing all this work.
Old Apr 14, 2018 | 06:13 PM
Drew's Avatar
Re: SMALL RUST SPOT IN CYLINDER, WHAT TO DO??
If it's above the ring, why would it matter, if it's below the ring it'll probably scrape it clean most rikki-tik the first time you crank the engine. If you're worried about it, little 600 grit wet or dry, lubed with WD40 would probably buff it off. Unless it's pitted, can you catch a fingernail on it? If it's that bad, hone or bore + hone, but when you say it's one spot, very small, and surface rust, and it rubbed off, its probably nothing to worry about.
Disclaimer: Kansas hayseed speaking, never had a minutes training in an engine building shop, so
Old Apr 14, 2018 | 06:46 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Thanks Drew. That's kinda the way I'm looking at it. Just looking for opinions to back up my thoughts on it. Been doing bolt on stuff for years, but haven't actually torn a motor down and put it back together since high school. It was in the ring travel, not above it. That's why I'm just slightly concerned. But yea, still feels smooth.
Old Apr 14, 2018 | 08:27 PM
NoEmissions84TA's Avatar
What Drew said - not a problem.
Old Apr 15, 2018 | 03:35 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Spent a few minutes looking closer at it today.
Old Apr 15, 2018 | 08:36 PM
Use scotchbrite and WD-40.
Old Apr 17, 2018 | 05:28 PM
George Klass's Avatar
Car: 1989 Trans Am
NEVER use scotchbrite. It has aluminum oxide in it. Just the dust from that stuff is a big engine killer. It's highly abrasive and will get into your bearings.
Old Apr 17, 2018 | 11:20 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
What about a fine emery? Like what you'd use on a crank?
Old Apr 18, 2018 | 02:43 AM
I assumed he would take the proper precautions. But good point.
Old Apr 18, 2018 | 11:45 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
I guess I can get the piston about halfway down and use masking tape to cover the bore. Just FYI, if this was a small block Chevy I was working on then no, I wouldn't be concerned at all cause they're so cheap to rebuild. Only reason I even care is cause it's(and to the moderators please don't close this thread because of this) is it's a duramax going into a truck I'm not even sure I'm gonna keep. Not gonna go crazy with it, but planning on more power than stock
Old Apr 19, 2018 | 10:29 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
It's just surface rust, nothin to be scared about just clean it up and put it together as long as all the other bored are clean. RUST NEVER SLEEPS
Dead Reckon
Feb 9, 2012 10:18 PM
augie1209
Jan 28, 2010 12:56 PM
GuitarJunki17
Jul 27, 2006 05:36 PM
Speedy Mike
Convertibles
Sep 30, 2005 03:35 AM
RockinGTA89
Mar 13, 2005 04:49 PM
