Distributor pickup coil spins ~30 degrees?
Old May 1, 2018 | 02:34 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Been a long time since I worked on traditional distributor engine. I was doing a "tune-up" on my 16,500-mile Formula and after removing the cap, vacuuming out all the flaky white flotsam and rusty dust, noticed the pickup coil would spin back and forth about 30 degrees. Is this normal? It runs okay, but seems weird to me.
Old May 1, 2018 | 05:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Distributor pickup coil spins ~30 degrees?
If it is the shield over the pickup coil that is normal.
If it is the actual pickup coil, although not sure how you can access it with the shield in place, should never spin. There is a locating tab to prevent that.
RBob.
Old May 1, 2018 | 09:46 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks! I'm sure that's it.
gta892000
Jun 7, 2015 01:42 PM
rithsleeper
Oct 21, 2014 11:12 PM
silvernblack
17
May 13, 2008 09:29 PM
redrummer
Nov 25, 2003 04:23 PM
