Not firing right up
Subscribe
May 14, 2018 | 11:17 AM
Why if my car sits it will fire right up but after driving for a while and starting it. It seems to take a bit to turn over??
Reply 0
May 14, 2018 | 07:28 PM
Re: Not firing right up
Because our lord Jesus Christ believes that your car has a higher purpose
Seriously...
Thats about as good an answer as youll get without providing key pieces of information such as what sort of car, year, engine, any modifications that youve done etc.
Reply 0
May 14, 2018 | 08:08 PM
Quote: Because our lord Jesus Christ believes that your car has a higher purpose
Seriously...
87 iroc 5.0
Reply 0
May 14, 2018 | 09:34 PM
carb or injected? if carb, is it Computer Controlled or mechanical.
if its carb'd you might be experiencing a bit of vapour lock. Even mine with a decent size pusher pump in the tank still seems to get a little bit of v lock after a warm run.
Reply 0
May 15, 2018 | 05:50 AM
Quote: carb or injected? if carb, is it Computer Controlled or mechanical.
its fuel injection, no mods, stock car and it's a 5spd
Reply 0
May 15, 2018 | 07:28 AM
When attempting a hot restart, does the starter crank the engine normally or too slowly?
Reply 0
May 15, 2018 | 02:44 PM
Starter is strong, seems more like a fuel thing... idk. I hope it's not the fuel pump?
Reply 0
May 15, 2018 | 07:14 PM
More likely that there may be injector or regulator leakage, allowing extra fuel into cylinders. Does it help to open the throttle slightly when starting hot? If so, that's another sign of excess or pooling fuel.
Reply 0
Subscribe
