head gasket??
Old May 16, 2018 | 10:48 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
head gasket??
I know im not a regular on here,but still love third gens So much I just picked up a 84 H.O z 5 speed,the guy said it might have a head gasket blown
I pulled the dipstick and it was milky brown,but thought I would drain oil anyway.The oil was extremely thinned out and smelled strongly of gas Looks like a new fuel pump on it.Where else would it b getting gas in the oil,or maybe that's why fuel pump was replaced and they didn't change oil? Or maybe the gas ate up the head gasket also Its a very solid car,and has most all original items,a garage find,still title from 86 where second owner purchased it.It shows 73k miles Think it might b true Give me a few thoughts,thanks
Old May 16, 2018 | 05:40 PM
Re: head gasket??
A head gasket won't put gas in the oil.
I think I saw that very thing the other night on that TV show "Stupid Human Tricks". Never underestimate the stupidity of a previous owner.
For reinforcement of the total concept, see my signature.
Old May 16, 2018 | 05:43 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: head gasket??
A blown head gasket will put coolant in the oil. Do a compression check on all cylinders.
Old May 16, 2018 | 07:27 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: head gasket??
Thanks its head gasket
Old Jun 12, 2018 | 10:37 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: head gasket??
Thought it was a head geasket,but upon taking it apart I found no bad head gasket,looked for engine block cracks,cant find any IDK what else could b causing water to get in to oil Just going to replace engine
Old Jun 13, 2018 | 05:58 AM
Re: head gasket??
The most common things that put coolant in the oil are bad intake gaskets and cracked heads, then a cracked block along the lifter gallery right above the lifters, from freezing.
As said, a blown head gasket in a SBC won't put coolant in the oil. Not surprised you didn't find one. About 95% of the time when that happens in this kind of motor, it blows between cylinders, allowing compression to exchange between them. Then as the gasket continues to deteriorate and erode it may eventually hit water, allowing water into cylinders or compression into coolant, but that's considerably less common than the between the cyl failure.
Butt hay, if you can't positively identify and definitely cure the source of the coolant/oil exchange, then trying to "repair" that engine is just about guaranteed to fail, since the fault is extremely likely to continue to exist. Replacing the whole thing might be the safest thing to do.
Old Jun 26, 2018 | 06:08 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: head gasket??
I have checked and looked at it for 3 days I don't c any cracks anywhere,same it was the original engine for what its worth,sometime 20 years down the road someone will b looking for it LOL I still have ecm in the car you think it will b ok with the 350 it is just stock
Old Jun 26, 2018 | 06:23 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: head gasket??
thanks sofakingdom,the cylinder walls was really bad anyway,looks like the engine was stuck,you could c where the rings left a imprint,guy said it was parked 20 years idk maybe it was intake gaskets.i will put it on run stand and check it out when I get down putting 350 in,just want to get it together
MattGibson1
Jan 8, 2014 05:59 PM
tsmash
Mar 31, 2012 12:50 AM
red92firebird
Apr 8, 2008 08:56 PM
blue86iroc
Mar 19, 2004 10:54 AM
IROC315
Nov 28, 2001 06:29 PM
