Need help identifyiing connector on 1987 IROC
Old May 30, 2018 | 09:56 PM
rudolphschenker's Avatar
Car: 1990 IROC Z, 1987 IROC Z, 1986 Fir
I cleaned up my wiring harness from the previous owner, and tried to carefully keep track of wire connectors with labeling. However, I can't identify one last connector. Has two wires, solid black and pink with black stripe. Plugs in somewhere behind the intake manifold.
Old May 31, 2018 | 03:36 AM
amfornal's Avatar
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
Re: Need help identifyiing connector on 1987 IROC
I think it goes to the EGR valve under upper intake manifold plenum.
Old May 31, 2018 | 05:41 AM
Twin_Turbo's Avatar
It goes to the egr solenoid originally bolted on the pass side intake manifold bolt next to the coil
Old May 31, 2018 | 08:52 AM
Drew's Avatar
Maybe... Many 87's have a weatherpack like that which doesn't go to anything. Mine does, I asked about it 20 years ago and several other people had the same plug on their 87s. I've been through every diagram for 87 and still haven't found anyplace it should be connected.
Old May 31, 2018 | 09:52 AM
I looked at the EGR carefully, when re-doing the wiring. Mine had tan wire and a black wire going to it and it's currently plugged into the EGR solenoid.
Old May 31, 2018 | 09:54 AM
As far as I can tell it doesn't connect any where. Looked at a lot of diagrams.
kevosiroc
21
Dec 12, 2019 10:51 AM
thirdgencrazy1
Oct 16, 2011 09:35 PM
john5.7 87Iroc
Dec 1, 2004 04:34 PM
