Can iroc air boxes be put on a firebird?
Old Jan 6, 2002 | 02:56 PM
89blackbird's Avatar
Hey guys can you put the straight in air flow y and air boxes on a firebird? My friend has a 1986 iroc and I like the air cleaner set up a lot better than my 89 GTA tin can set up. Will my hood clear?
Old Jan 6, 2002 | 04:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
No, the hoodline of the firebird is much tighter to the radiator support than the camaro. I'm not positive but, I don't think it would even work if you cut the reinforcement from the hood.
I've tried this already and found out the above.
Old Jan 6, 2002 | 05:15 PM
Yea,I thought maybe that was the case. The intake on the firebird is terrible. I will have to see what can be done with this as soon as the engine is done. thanks
Old Jan 7, 2002 | 07:39 AM
GRENDLE's Avatar
what he said, the hood line is too tight. has anyone tried this though? if you cut out behind the hood vents, and were to find/make an angled/formed box that would hold a stock size flat filter and run that straight into the TB? i was trying to think of something that came with a similar box then adapt it to work (4th gen ram air? stock housing from a truck or full size car? ). it'd be a bit wierd as it would have to be real flat or bulge down to sit a little lower behind the radiator support (tight fit). simple ram air.? just wondering
Old Jan 7, 2002 | 11:08 AM
Guest
Guest
Posts: n/a
I set one on my car, it was nowhere near close to fitting. Dont think cutting will help.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
